Thread: Aeration
    cgin40's Avatar
    Mar 2015
    Rowlett/TX
    2
    Aeration
    I understand that aeration increases PH. Can someone explain why? Curious minds would like to know.
    Along those lines, would borax help stabilize PH in an outdoor pool with a water fall?
    Dave
    Dave
    13,000 Gal Outdoor Plaster
    1,200 Gal Spa
    48 sq ft DE filter with Polaris Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Aeration
    Aeration allows carbon dioxide that is dissolved in the water to more easily outgas. The carbon dioxide leaving causes the pH of the water to rise.
    Borates can help stabilize your pH. It's not magic, but if you are interested, read So you want to add borates to your pool--Why and How
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Aeration
    It's exactly the same principle as shaking a can of Coke. It's not as concentrated as the Coke, so you don't see it erupt and fizz, but it's releasing the gas and the pH rises.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Aeration
    Carbon dioxide that outgases is the same thing as removing carbonic acid from the water because of the following equilibrium:
    H2CO3 <---> H2O + CO2(aq)
    Carbonic Acid <---> Water + Aqueous Carbon Dioxide
    Removing an acid from the water raises the pH because the bicarbonate in the water (mostly measured as TA) is in equilibrium with the carbonic acid so the following moves to the right consuming hydrogen ion so raising the pH (since pH is a measure of the amount of hydrogen ion in the water):
    +TA .... -TA
    HCO3- + H+ <---> H2CO3
    Bicarbonate Ion + Hydrogen Ion <---> Carbonic Acid
    The TA does not change with this process because carbonic acid is a weak acid so the drop in TA from the loss of bicarbonate equals the gain in TA from the loss of hydrogen ion (i.e. from the gain in pH).
    Aeration increases the rate of carbon dioxide outgassing because it increases the surface area of the water/air interface so the exchange of carbon dioxide from water to air can occur faster.
    Re: Aeration
    I love this site. You get some easy to understand answers and then hard core science to close the book on it.
