Thread: Algae Issue
    Algae Issue
    Having a problem keeping algae away. I keep FC between 4-6 and CYA is 60-80. We have had some rain and haven't swam in 4-5 days and I keep it covered with a solar cover. When I take the cover off you can see algae in the corners and creases of the deep end and also some on the deep end floor. I know everyone says phosphate levels don't matter but I'm beginning to wonder? Thoughts? Thanks!
    18x37 IG 22,500 gallons...Vinyl Liner...Hayward EC-65 DE Filter...Hayward 1HP Super Pump...Aquarite SWG...TF-100 test kit.
    Jan 2014
    Buckeye AZ
    807
    Re: Algae Issue
    With a cya of 60, your FC minimum is 5. With a CYA of 80, it's 6. So if you are unsure of your CYA, round up and keep the FC at a 6 minimum, which means getting it up to 9 or 10 at the start of the day.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Algae Issue
    What size Aquarite unit do you have? How often do you test? How old is the cell? Are you sure it's producing
    38,262
    Re: Algae Issue
    Quote Originally Posted by BuckeyeChris View Post
    Those numbers are true for a non SWG pool.
    Jan 2014
    Buckeye AZ
    807
    Re: Algae Issue
    oh, I see in the sig now. but, it would seem the maintenance level still needs to be higher than the OPs current target
