Results 1 to 12 of 12
Thread: New Pool owner needing advice
    Jul 2015
    West islip, NY
    9
    Quick background on my pool.
    My pool before I purchased home was covered during the winter of 2012/2013 with a terrible pool cover surrounded by trees. Pool was opened (just for inspection in April of 2013 and cover thrown out) and left unattended while we closed on house which did not complete until late August of 2013. No time to start pool before winter, so purchased new pool cover and covered pool as is. Now summer of 2014 comes and I begin my battle (as a first time pool owner). Many hours shocking, back-washing, cleaning filter, adding DE, and skimming the million leafs from overhead trees. Just had it almost clear and left for a wedding in Hawaii for 10 days, came back to a green pool from leafs. Almost get it back again and old pump goes, takes a couple of weeks to buy a new variable speed and getting connected and green again. Lose another pump, but there are points last summer that it was clear even with all the headaches.
    Open pool this year and looks much better than last. I have all the trees taken down in the spring, but still in two months can't get pool clear. I've added a ton of chlorine (before I found this forum), I guess mostly Dichlor (Leslie brand, blue seal, chlorox - not bleach) and green out from Leslie's. Found this site, tested my chlorine and PH (only tester I have at the moment) both non existent. So got borax and brought my PH up (7.8) took my water to local store to get tested (wanted to see CYA so I can check the CYA/Chlorine chart). They say numbers look good but chlorine (0.9), but I see that my CYA is 162 and ask if that is a problem (they don't think so)
    1st question: CYA is extremely too high correct...............I need to drain at least half my pool?
    2nd question: This old DE filter of mine has me concerned (can't buy a new filter now), but it says 8 scoops on the side. Everything I read says one scoop/10 Sqft on the internet. This is 35 SqFt so I think 3.5 scoops should be enough?
    Thanks in advance
    22,000 Gallon in-ground
    Jacuzzi 35 SqFt DE Filter (10+ years old)
    Hayward Variable Speed Superpump (1 yr old)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Pool owner needing advice
    Step 1 before answering any questions is to get a good test kit for home testing. It's more accurate than the pool store. You will not get advice here without a recommended test kit: Pool School - Test Kits Compared The TF-100 from tftestkits.net is the best value but the Taylor K-2006 is also serviceable.
    Only when you get your test kit will you know what your actual CYA level is or your actual FC (free chlorine) level is. Pool stores testing is worth exactly what you pay for it. Nothing. It's just a way to get in you in the door and sell you what you probably don't need.
    Get a test kit ordered and until it arrives, add up to a gallon of bleach per day and keep it circulating and read some articles in Pool School, starting with ABCs of Pool Water Chemistry.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Jul 2015
    West islip, NY
    9
    Thanks for the quick response. Looking at kits on Amazon now. But assuming CYA is >100 just to shock my pool I will need like 10 gallons of bleach and then maintain those high levels?
    Also any thoughts on DE scoops?
    Feb 2014
    Central Minnesota
    5,080
    Amazon kits might be fine but do yourself a favor, get the best kit available, at the best price with the BEST customer service you can get and get the TF-100 from tftestkits.net.
    You will need lots of chlorine to bring the pool up to shock levels and based on what you find out about CYA, you might be best served draining the pool to bring down the CYA. But that CYA number from the pool store is about as good as a guess.
    Perhaps someone with more experience with DE filters will drop in on that question.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Do you have a model number for your filter? We can go from there.
    The 10 gals of bleach will be just a START with your CYA high like that. It would not be worth it. If you really want to you can drain your pool by 25% and see where that gets you. BUT the pool store testing of CYA is the worst we have seen in most places.
    Where is West islip? My google search says NY. If that is correct can you please add that? THANKS!
    Kim
    Jul 2015
    West islip, NY
    9
    Yes NY (just added -sorry). The filter is Jaccuzzi EW75 DE filter
    Jul 2012
    Tallahassee, FL
    30,476
    I cannot find any info in the three searches I did oh how much DE to add.
    I think you should start a new thread just for this questions so the DE owner/users can see it and help you out.
    BUT saying that.............my gut says.........it says 8 cups on the side for a reason???
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    West Islip is on Long Island, Kim
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Here's a link to your manual:
    http://www.wep.co.nz/wep/member-imag...s%20Manual.pdf
    It says 8 scoops or 6 lbs of DE. The Hayward 36sq in filter sez 4.5 lbs, so maybe the rule of thumb you found was for a different size scoop.
    Good luck!!!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Jul 2015
    West islip, NY
    9
    So here it is, tested CYA and it is 80/90.....probably closer to 90. So high but not high enough to drain? So by my calculation I need about 6 gallons of bleach (12.5%). About my filter I actually use the old coffee can.....so we think I should use 8 scoops?
    Jul 2015
    West islip, NY
    9
    So CYA was 80, and I added 6 gallons of bleach (12.5%) and 8 Scoops of my DE on Saturday evening, Sunday morning my pool went from gross green to a cloudy blue/turquoise. Sunday and Monday I had no time to test pool, but filter has been running 24/7 and still no change to clear. Should I assume that the algae is dead and now I can aim for target FC of 9 or do I need to SLAMM again? I should be able to test tonight, but want to make sure I have enough bleach on hand if I need to hit it hard again? Thanks
    Jul 2012
    Tallahassee, FL
    30,476
    Steg, you did not do a SLAM. You just hit it one time with bleach. Here is the link to doing a SLAM. The MOST important part of the SLAM is the M=maintain part as in maintain the FC at the SLAM level at all times. Do NOT let it go below it if at all possible.
    Pool School - SLAM - Shock Level And Maintain
    Get a lot more bleach please.
    Kim
