Results 1 to 10 of 10
Thread: Sparkly to Green in Hours (Pics)
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Faithful TFP'er here.
    Had a big storm last night. Due to some in-progress landscaping the rain water ran over exposed, recently raked, loose dirt plus some fertilizer-rich sod and into the pool.
    Searching previous posts the recommendation with dirt in the pool is to let it settle and vacuum but the DE filter only has push-pull handle so this is not an option plus the water is green.
    TF-100 as of 7pm last night, before storm:
    FC: 6
    CC: 0
    pH: 7.5
    Temp: 84
    Results from Sunday (7/12)
    cya: 40
    CH: 250
    TA: 100
    When the rain stopped I checked the pool and even with a flashlight knew all was not well. Normally I can see the bottom in the deep end with a flashlight as though looking through glass.
    About 2-3am this morning:
    Skimmed debris
    Backwashed to reduce water in pool.
    Recharged DE
    Added 12.5% chlorine to raise FC to 12
    Ran filter for an hour and shut off
    6:30am:
    Turned on pump
    Vacuumed dirt that had settled
    Added MA to drop FC from 7.5 to 7.2
    7:30am
    FC: 11
    CC: .5
    Added 12.5% chlorine to raise FC to 16
    Temp: 82
    8:30am:
    Backwashed and recharged filter
    9:30am:
    FC: 16
    CC: 0
    My plan is to continue SLAM unless anyone recommends otherwise. Open to any additional recommendations - and yes, I do realize POP will be needed
    And for the pics:
    Overall pool (pic looks worse than pool):
    Steps:
    Deep End (thermometer in water):
    Pool Deck:
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Jun 2014
    15,144
    Re: Sparkly to Green in Hours (Pics)
    I think you're on the right track - continue your SLAM. That's unfortunate about the rain run-off. That happened to another forum member yesterday as well. Good luck!
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Thanks Texas Splash!! I appreciate the confirmation and well-wishes.
    Just wanted to be sure and I thought fellow picture-hungry TFP'ers would enjoy the pics.
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    A quick slam should have it clear in a short time.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Thanks pooldv!!
    TF-100 Test Kit
    domct203's Avatar
    Jun 2015
    CT
    3,587
    Not to hijack, but if FC levels were maintained properly, how could this happen?
    Edit:
    Is it because of the volume of organics added to the pool overwhelmed the FC, reducing it to 0 in a short amount of time?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Hi Dom,
    The FC was not reduced to 0; in fact I have no reason to believe it dropped below minimum FC levels.
    So far there has been no loss of FC since raising it to shock level this morning.
    There has been a lot of dirt in the backwash water the 2 times it's been backwashed today.
    TF-100 Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If your FC didn't drop then vacuuming and filtering should very quickly clear the pool and a full SLAM may not be required. However if organic matter is left in there for any length of time you will see the FC drop.
    chiefwej
    domct203's Avatar
    Jun 2015
    CT
    3,587
    That's perplexing, theoretically it should have been impossible for algae to bloom.
    That may not even be algae.
    Dom
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Progress, incl. pics
    2:30pm
    FC: 15
    CC: 0
    Pool normally looses 1.2 to 2 ppm FC per day. Despite the color this morning nothing indicates an algae bloom, just dirt. Have backwashed and vacuumed again.
    Overall:
    Steps:
    Deep End:
    Quote Originally Posted by chiefwej View Post
    Thanks chiefwej.
    Quote Originally Posted by domct203 View Post
    Dom
    I agree
    TF-100 Test Kit
