Results 1 to 12 of 12
Thread: Spa jets have no power like it use to?
    Jul 2015
    Fremont ca.
    6
    IG pool with spa on the side. The motor seem to pull the water from the spa but dose not shoot out like it use to . Could this be the motor ? I have 2 intake at the bottom of the spa one that shoots the water from the heater works good but the other has not much suction but enough to dribble some water out. The blower works fine. When I turn the blower off you can feel little water flow coming out. Any help with matter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Spa jets have no power like it use to?
    Welcome to TFP!
    Maybe the filter is clogged and needs cleaning? What is your clean filter pressure? And current filter pressure?
    Jul 2015
    Fremont ca.
    6
    The jets do not run through the filter that has a pressure gage, just the basket attached to the pump .
    Jul 2015
    Fremont ca.
    6
    There is one that is hooked in line with the filter and heater that dose come out into the spa. This one is fine. The jets which there are 4 are the ones that suddenly now are dribbling out with no pressure.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Are those jets run off a separate pump? Is the pump making unusual noise?
    Either the impeller is damaged or broken or there is something stuck in the spa jets.
    Mark
    Jul 2015
    Fremont ca.
    6
    Quote Originally Posted by mas985 View Post
    Yes jets do run on a separate pump, no unusual noises are coming out of the pump.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I had maple tree helicopters get in my spa jets this spring when I opened the pool. I wasn't also getting any bubbles from the air intakes because of it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    DFW, TX
    24,502
    Take the jets out and make sure there isn't debris lodged behind them. We've seen that happen before.
    Jul 2015
    Wall, NJ
    9
    Are the Jets turned on. Turn the bezel, on each jet, counter clockwise.
    Jul 2015
    Fremont ca.
    6
    Quote Originally Posted by HQPools View Post
    There was a post that the bezel might be broken would that not shoot the water ?
    Yes the jets turn on just no power .
    If the impeller is damage what happens?
    mas985's Avatar
    Pleasanton, CA
    11,741
    If the impeller is plugged or damaged, the pump will reduce flow rate. Your jets will not be as strong as they should. Clogged spa jets, same thing.
    Mark
    Jul 2015
    Fremont ca.
    6
    Sent from my SM-G900V using Tapatalk
    Thanks for that information I got it working I do believe it was the impeller stuck , I ran a hose full blast into the pump motor and got it loss some how ! I put the lid back on the pump and it pulled the water in with more force the flow rate increased a lot. Turn the blowers back on and I was back! Sweet! I thought I was going to have to buy a new motor. I hope this was just a one time issue with this! Thanks again
