Thread: Contractor Replaced Pump, did he slightly unseat my ball valve
    My contractor installed a new pool pump, but I think he unseated the seat collar on my ball valve by a hair.
    It leaks a drop of water every few seconds. See the drop at about 4 to 5 o'clock in the picture.
    Should he undo the new pool pump and attempt to reseat?
    Trapezoid shaped pool, 27500 gallons, plaster, pool pump in basement, soon to be heated by combo solar pv/thermal system.
    Jan 2012
    340
    Re: Contractor Replaced Pump, did he slightly unseat my ball valve
    Can you give us a wider picture? Also looks like the ball valve might have Union connections. If so, have you tried tightening those up?
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    I added a second photo to the original post. The white PVC is the existing PVC.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    looks like it also a union turn off the pump, unscrew that union and lube it, and put it back together... should fix it
