Thread: vinyl a little to one side
    djisarob
    Guest
    I have a question about set up I have everything level the site, the poles, ect. but the liner got set up a little to one side, not a lot but bulging against the bottom of the leg a little on one side compared to the other legs. It is about half way filled and was wondering if it will be ok or should I drain it (UGH!) and start over
    Thanks in advance, Rob
    Orlando, FL
    690
    Re: vinyl a little to one side
    You should drain. It could be fine or it could burst and someone could get seriously hurt. I have been where you are and feel your pain. However, if you do not fix it now, you will always be bothered by it and never get a good night's sleep. Lol. No seriously, I speak from experience. Let the draining begin.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I'm guessing the ground is not level? The way they hang from the frame, it usually bulging due to a low spot. Unless the legs didn't get leveled and straightened while it was filling.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    This happened to us last year. Paving stones were level and under the feet, but it was windy and we didn't get the fabric centered in the center of the pool. We filled all the way up thinking it might correct itself, but it id just what you are describing. If I had known, I would have drained. Sorry to say it, but drain now. When ours was full, it leaned badly on the posts on one side and looked horribly unsafe. We ended up fixing it with an engine hoist by popping 3 legs out on to new paving stones a little further out, but that was very risky and I can't recommend it. Good luck!
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    djisarob
    Guest
    Well everything was level when we started and also during the filling process. We too had a heavy wind and did not get the liner centered. It is being drained as I type. Hope we can center the liner this time without the winds help.. Any suggestions on getting the wrinkles out. I also have a question as to whether the seem around the bottom outside should lie flat or up the wall a little?
