Thread: To SPA Actuator (turned on manually), I not stopping the water from filling the spa.
    Jul 2015
    farmers branch/TX
    2
    I have two automated valve actuators (Pentair), one TO the spa, the other FROM the spa. They have worked just fine, .....installed last 01/2015. (I use them manually during the summer). This morning I turned the "TO SPA" o "OFF" so that I could empty my spa. The CAM moves just like it is working. The Actuator went to off, BUT water keeps coming into the SPA.
    The CAM turns, so there is electricity getting to Actuator. I took the top off the actuator (only the first layer) but didn't want to go any further than just that. All the wires are intact. But I know it is not the power. Is this something that can be fixed? Or how to further trouble shoot.
    I have turned the actuator all the way open and all the way closed several times..... to no avail. Power is there. But no change in water to SPA...
    ps0303's Avatar
    Jul 2011
    FL
    3,699
    Re: To SPA Actuator (turned on manually), I not stopping the water from filling the s
    Turn the pump off and then remove the acuator and see how the valve turns by hand.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2015
    Wildomar, California
    423
    Check to see if the valve shaft us pushed all the way down into the gears. A couple times I had one pop up and the diverter wouldn't turn. Also check to see if the valve shaft is sheared off. That's happened before.
