Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Need vacuum hookup help for intex without skimmer. Picture and backstory inside.
    May 2015
    Southern Illinois
    49
    Ok, so this is starting to drive me a little mad, this is what has happened thus far. We bought a hose from walmart that was a 2inch, 35 ft hose and set out to find something that would fit into the white hose coming out of the basket (which I have a spare for) and fit onto the other end of my vacuum hose.
    I ended up with this contraption thanks to the guys at True Value (I am not handy) . That did not work as I kept losing pressure because it wasn't airtight. Even after gluing it all with pvc pipe glue there was still air leaking and I couldn't get pressure.
    So then I got this magical piece that actually worked . I had two wonderful vacuuming sessions where I had great pressure (as opposed to having the girlfriend hold the tube up to one of the two returns and getting very light pressure which is annoying for everyone).
    But all good things end. Oddly it cracked in between uses somehow but now this hose is kaput as well and I'm starting over.
    So I figured I should probably come here because you guys have always helped me out of a jam. I am using the 28651EG Intex Krystal Clear 3000 GPH Sand Filter Pump and am wondering if anyone has an easily repeatable solution (hose/piece combo) that will fit allow me to connect my vacuum hose (which I will have to buy now) to my spare white hose.
    26' Intex 17k gallon above ground pool. 3000 GPH intex sand filter. Taylor Tech. k-2006 Test kit.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Need vacuum hookup help for intex without skimmer. Picture and backstory inside.
    I am watching with interest, as I have the same set up. Right now I have the hose that was attached to my old 18 foot Intex's over the wall skimmer with the threaded end. A little duck tape, and it worked, but I haven't tried it on the new pool. It has the double inlets, not sure how to get it to work well.
    May 2015
    Southern Illinois
    49
    Yea, I bought one of those skimmers and couldn't get the clamp to fit over the rail. Even if I did it, the height was also way off so I sent it back. If yours fits let me know what brand it is as I would be willing to give it a try.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I meant I took the hose off off the skimmer to hook it to the inlet of the old pool. I used duct tape to hold it together. A little redneck, but hey, it worked! Not sure if I can get it to work on the new pool. I may use my back wash hose (extra Intex hose with the regular threaded end) and try to hook it right to the pump, by passing the double inlets. Have only had the pool filter running a few days, haven't had time to fuss with it. Was going to tonight, but my son has a friend over, and they are using the pool right now. Here is a pic of what I meant.
    [URL=http://s291.photobucket.com/user/EdBeth/media/image.jpg1_zpsedptdrep.jpg.html][/URL
    Please post a pic of the intake and return on the pool where your hoses connect going to your filter.....check out my past post on your issue.....your set up should be the same as mine
    24' x 52" VINYL AG 15,200 GAL.
    HAYWARD POWER FLOW LX 1.5 HP
    HAYWARD SAND FILTER
    Taylor K-2006
    Jul 2015
    Anrews/Texas
    50
    Intex 20' x 52" Ultra frame pool w/ 1,600-Gallon sand filter.
    May 2015
    Southern Illinois
    49
    Drywall guy, I will get another picture tomorrow when the sun comes out. It is the white hose at the bottom right in my first picture.
    RickW, thank you! So that will fit right onto the leaf basket and then connect to a 1 1/4 hose, correct? I just want to make sure I have it straight before I buy.
    Check this thread and see if this helps you....
    Coleman (Intex) filter vacuum attachment
    HAYWARD SAND FILTER
    Taylor K-2006
    May 2015
    Southern Illinois
    49
    Quote Originally Posted by drywall guy View Post
    Oh, you mean running it through the inlet? My pool has two and they are rather small, I don't get very good suction when I do that and I had to rig up something to keep them secure (one slipped off and lost a lot of water, they are cheaply made) and it makes the circle not uniform so the plugs also don't fit. I am wanting to hook up the vacuum hose straight to the prefilter on the pump.
    Apr 2013
    North OKC Area
    300
    Can't help with intex stuff, but your hose is fine. Cut off the white end and get a new one. Use PVC glue to put new one on. I think I got my replacement end from Leslie's.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    May 2015
    Southern Illinois
    49
    Thanks for the tip, DanielP! I didn't know you could replace it. I still need a new solution as the last one cracked it in short order.
    Apr 2013
    North OKC Area
    300
    Sorry I can't help you on intex fittings yet. My neighbor has recently been put in the same situation so if we figure something out before you I'll let you know. We probably won't work on it together till this weekend. I've seen videos of hard plumbing intex pools so that may be a route we go at least partially. I'm thinking that we need to make an adapter to go from inex hose to hard PVC. Then put union on hard PVC to pump. Get a second union for vac hose, but only use one end that will fit to union that was added to hard PVC after the intex adapter. I will probably leave extra pipe between intex to pvc adapter and it's union in case I need to add a shutoff valve to prevent collapsing the intex hose while vacuuming. Of course everything works out better in my head than real life and actual plan depends on neighbor.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by dustbin3 View Post
    I'm not a fan of the new setup so far. Heading out soon to see if I can make what I used last year on the old pool work on this one. Checked to see if that blue thing would screw on the place that the inlet cover comes off of, and it did, not sure if it will be airtight though. Concerned that I have to take both pieces off to plug the other inlet, so I get enough suction. That's why I, like you, was considering hooking up right to the pump. I dug out the extra piece of Intex hose I had that came with the sand pump. Crossing my fingers I can vacuum. I don't have a solar cover yet, lots of bugs on the floor.
    May 2015
    Southern Illinois
    49
    Good luck and let me know how it goes PAGirl, I am also going to try a few things, will report back here with results. We'll figure this out.
    Jul 2015
    Anrews/Texas
    50
    You unhook your inlet going into the pump. hook up the adapter, fill your hose with water and cover the end with your hand to hold the water, bring it out of the pool and slide over adapter gets everything a little wet from the siphoning but works great for me will upload pictures if i can ever get the email to send from my phone
    Jul 2015
    Anrews/Texas
    50
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    I simply unhook the skimmer hose from the inlet and hook the vac hose up to the inlet.
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I will have to try Rick's way. My current setup worked okay, but the debris got stuck at the small opening of the inlet. I cleaned it, and it worked well enough again. Was worried about the black plug, it fit over the blue part, the suction held it in place.
    Jul 2015
    Anrews/Texas
    50
    I was going to do it through the skimmer, but I was concerned with the other inlet being open still that it wouldn't provide enough suction. Plus I already had this connection laying around. It also works to screw onto the discharge of the sand filter to use the long vacuum hose to get waste water away from pump and pool when backwashing
  20. Back To Top    #20
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I had been contemplating doing that when I first set up the new pool, glad to know it works! Do you closer the plunger valve, and turn the filter to closed while hook in it up? Wondering how to minimize water loss.
    I have an extra hose, like the one that goes from the pump to the plunger to the outlet that I may try to make work.
    Heck with it, I'm buying the adapter! Sorry to hijack the post!
