Results 1 to 9 of 9
Thread: Polaris 380 Gets Stuck
    Hello,
    Hoping someone can tell me what might be happening with my Polaris 380. I just had it checkout by my Polaris Dealer (Leslie Pools) and they said all is well. I've made a run through the Common Polaris 380 Problems and Troubleshooting http://www.epoolshop.com/polaris380p...eshooting.aspx without help. RPM Check looks to be around 26 - 27.
    Any ideas why it might be doing this?
    Thanks very much for any help.
    Jeff
    Here's a quick 30-second video to show you exactly what it's doing
    [youtube:1phjy47v]_v6bCy-MupM[/youtube:1phjy47v]
    sammm's Avatar
    North Richland Hills, TX
    257
    Re: Polaris 380 Gets Stuck
    Isn't there a 'reverse valve' further up that hose? #56 in the diagram. It should activate ocassionally and send the Polaris backwards.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Quote Originally Posted by sammm
    Yes. I just bought a new "reverse valve" and put that on last weekend. It is blasting and appears to be working correctly.
    Jan 2009
    Cupertino, CA
    1,966
    It looks like the hose is taut, and is holding the unit back. That happens with mine if the hose gets a loop that won't untwist by itself. Sometimes that means you need to replace a stiff swivel, sometimes it just happens. (Or maybe the hose isn't quite long enough.)
    After the backup cycle, does it change direction and behave normally?
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2008
    Central Texas
    326
    It looks to me like you have the float on the Polaris set too far back. Move it so that the front edge of the float is about 3/4's of an inch from the downtube and see if it doesn't work better. When the float is way back like that it tends to lift the rear of the unit too much.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Yeah, looks to me like you're not getting any traction on the back side. Slide the float in, and if it's not already set the nozzle on the back so that it's pointed up at about 11:00.
    Apr 2008
    Central Texas
    326
    Once set up properly, it should easily climb the walls. My 280 has no problem climbing up the 9 foot walls in the deep end and touching the front wheels against the coping tile before it heads back down. 8) 8)
    Polaris 280
    Just a quick follow up on how this issue was finally resolved. There were a few issues affecting the Polaris 380. First the Polaris 380 Float head was slightly cracked and had some water filling up inside. Second, the Water Management (WMS) system had hoses that were not longer sealed correctly as they had been "fixed" by using zip ties at some point in the past. Finally, the PosiTrax tires need to be replaced as they were very worn. My local dealer replaced these parts and now my Polaris is ripping along nicely.
    Thanks very much to everyone who posted replies to my original post last month.
    Just a note: the zip ties on the hoses inside the Polaris are supposed to be there. Its not a 'fix'. If they happen to break they need to be replaced as it affects the water mgmt function. Ask Leslies if you want to make sure I am speaking the truth.
    16X37 30,000 GALLON INGROUND GUNITE/ PLASTER MOUNTAIN LAKE WITH DE FILTER BUILT 1987
