Results 1 to 7 of 7
Thread: EC65 filter problem
    Jul 2015
    Akron OH
    3
    EC65 filter problem
    Filter is not filling to top. Pressure air release on top does not have any air or water shooting out. Cleaned fingers with acid bath, replaced top gasket. Psi is 15 after cleaning. Prime basket has air bubbles. Have checked lines from skimmer and found no leaks. Dug up lines and no leaks. have tried everything I can think of. Any suggestions? System worked until cleaned fingers with acid bath. Also lubed o-ring on prime bowl. It returns water to pool but suction is very minimal only fills prime bowl to about half full.
    I have a 16x32 in-ground pool. It has a Hayward EC-65A filtering system. It holds about 18,000 gallons of water. The system was installed in 1987. It has a vinyl liner.
    22,553
    Re: EC65 filter problem
    When you say prime bowl, do you mean the bowl that's on the from of the pump? If so there's air getting into the system somewhere on the suction side of the pump.
    Jul 2015
    Akron OH
    3
    Yes I know. Have checked all lines even dug up under ground lines. Found no leaks. Real problem is filter it's self not filling to top. It always filled and could release air with top release valve. Problem started after cleaning filter fingers.
    22,553
    Sounds like the vent valve is stopped up. Have you taken it out completely and checked in the port to see if it's plugged?
    Jul 2015
    Akron OH
    3
    Yes. Some bubbling of water comes out.
    22,553
    Sounds like there's too much air in the system for the pump to prime and pump fully.
    I think it was a coincidence that this happened when you cleaned the filter.
    Can you post a pic of the equipment pad, especially the pump near the suction area?
    Have you removed the drain plugs on the pump and strainer basket and cleaned and resealed them? there should be more than one.
    Jul 2015
    Carlisle PA
    15
    This happened to me because the lid was not turned fully to the closed position on the pump basket. I tapped it to fully closed with a rubber mallet and that did the trick.
