Thread: Poor Skimmer Function
    May 2015
    Somers, NY
    2
    I've been lurking on this site for a little over a year now and have really learned a lot from pool school and doing searches. I even bought a Taylor 2006 kit that was recommended here and it is great. I have an 18 x 36 vinyl liner inground pool with a sta-rite system 2 cartridge filter and 1hp sta-rite supermax pump. The problem I'm having is with my skimmer not really doing much, and I think it could be because I cannot get good flow around the pool. The pool only has one skimmer box, a suction line, and 2 returns (one of which is at the steps). I get good suction from both the skimmer and the suction line, but bugs and leaves still tend to stay in the middle of the pool rather than go toward the skimmer. I've attached a rough sketch of the pool. Which direction would you recommend I point the returns for best flow around the pool?
    18 x 36 Vinyl Liner IG Pool, 26,000 gallons, Sta-Rite System 2 PLM175 Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Poor Skimmer Function
    Welcome to TFP!
    I'd probably start by aiming the return in the steps toward a spot about halfway between the skimmer and the wall on the right. Then I'd aim the wall return into the upper right corner, with both returns rippling the surface a little.
    Jun 2015
    Wildomar, California
    423
    Do you think that closing down the suction line thereby increasing the skimmer pull would help, plus doing the aforementioned return adjustments?
    May 2015
    Somers, NY
    2
    I changed the direction of the returns the way John T recommended and this morning the skimmer box has much more than usual in it and I don't see nearly as many bugs floating around. Seems to be working. Thanks!
