Results 1 to 7 of 7
Thread: and so it begins... (pool build in N.TX)
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    Hi,
    I was all excited to post my pic of my construction just beginning... but I got error after error saying the pic was too big, even at 100 pixels wide. It finally let me upload at 1.73 KB. I am quite sure all you will see are mosaic squares.
    At any rate, my pool build has begun.
    About to build an in-ground free-from gunite pool in the back yard (no spa). Currently estimated at 19,000 gallons. Likely going with a SWG.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Re: and so it begins... (pool build in N.TX)
    Looks great!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Eddd View Post
    Hi,
    LOL, if your going to be adding a lot of pictures, try using IMGUR
    Posting Photo's Tutorial
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,422
    Eddd you are a tease! Even my reading glasses do not help me see that tiny thing wahhhhhhhhhhhh I wanna see! LOL
    Kim
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    The picture is about the size of a TicTac for me! Sorry I can't help you fix the problem, but I will encourage you to keep trying. I'm looking forward to seeing your build!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Hi,
    Dang, that is smaller than your avatar. Let me find my magnifying glass.
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Eddd,
    try this
    Divin Dave,
