Results 1 to 13 of 13
Thread: New build, can I partially fill for a few days?
    Jun 2015
    Dewinton, Alberta
    73
    We are just in the process of setting up our 27ft round steel-wall above-ground this week. The ground is finally level, and we're renting the plate compactor tonight. We'd love to get it all set up this week, HOWEVER....we are going camping for 4 days this weekend. We're not really comfortable filling the pool entirely, and then having the heater/pump/filter running while we are away and unable to fix a problem that might arise. I understand the pool requires some level of water to help support the walls....so, I'm wondering whether I can half-fill the pool before we leave, and that way when we get back, we just need to fill the rest of the pool and hook up the filter etc.....
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: New build, can I partially fill for a few days?
    Yes that would hold the walls....but then without care it can go green, then you have to deal with that.
    I wonder if there is a chemical mux one can put in to keep it from blooming.....like some CYA and chlorine maybe?
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Jun 2015
    Dewinton, Alberta
    73
    We'd be filling with fresh well water, so no chlorine or treatment at all....I imagine it would get slimy pretty quick if just left to its own devices!! I imagine adding some 'extra' chemicals or something of the like at the beginning, and then when we refill the second half 4 days later it would help to balance out a bit. I'll do a little Pool School reading and see if we can come up with something!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    I say fill it up all of the way.
    -add enough CYA to get to 10ppm BELOW your target level. You are going to have to hand squeeze it all in unless you pay for the liquid CYA. I had squeezed all of mine in over a couple of hours. I wanted it IN!
    -Get a puck holder and put 2 pucks in it in your pool and let them float around and add their chlorine and CYA at the same time.
    I think you should be good with this method for your trip.
    Oh and I would use bleach or chlorine (whatever you will be using on a day to day basis) to push your FC up to SLAM level right before you leave. Make SURE to get is mixed in good!
    Kim
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I second the CYA below target, and a floater with a couple of Chlorine Pucks. I also second enough bleach to get it to target shock level for that CYA that will be there. Mix well and enjoy your trip. When you get back, it will be short work until you are swimming.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Will a floater work at all with no circulation?
    Jun 2015
    Dewinton, Alberta
    73
    Thanks for the tips so far!! We are hesitant to fill allll the way, just in case something catastrophic happens while we are gone. Half the water, half the damage??
    Jul 2012
    Tallahassee, FL
    30,575
    Steph, It is up to you. I am just telling you what I would do.
    Kim
    Jun 2015
    Dewinton, Alberta
    73
    Worst case, the yard is sloped off away from our house...so there's that
    27 foot round above ground pool, steel walls and resin uprights/top rails/foot covers.
    1.5 HP Hayward Turbo II pump, 24inch, 300# Hayward Sand Filter, Hayward 200,000 BTU natural gas heater
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Is there any reason for you not to fill it all the way?
    Jul 2012
    Tallahassee, FL
    30,575
    There is that! LOL
    Kim
    Orlando, FL
    690
    My installer had me fill the pool 1/2 way and then he came back the next day and cut the skimmer and return. Then, he left me to fill it the rest of the way. Not four days but filling half way was enough to prevent trouble. I would mix some bleach in a 5 gallon bucket of water and broadcast it around the pool water. Go camping.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2015
    Dewinton, Alberta
    73
    Morzh- the only real reason would be that it would be a new setup, and we'd not be here to see if anything catastrophic happened. I'd hate to come home to a collapsed pool and flooded yard!! But, what am I really going to do about it if I am here...stand outside with a bucket?! We are stalled anyway right now, as there are thunderstorms in the forecast and it is raining. Grr!
    Thanks for all of the chem advice! My hubby is going to Pool School today!
