Thread: Storage of Test Kit
    Jul 2015
    PA
    17
    Storage of Test Kit
    When I purchased my test kit from the pool store, they told me to keep it stored at room temperature. I had a buddy of mine over to check levels while I was away on vacation for a few days and I forgot to mention to him to put it back in the house; so he stored the kit in my detached garage which is not climate controlled. I assume the reason is the reagents are temperature sensitive. Do I need to buy all new reagents or will I be ok? Was in elevated temperatures 80F-90F for 4 days. I'm finally rid of the algae after my filter crapped out and needed replaced and I really want to get dialed in on balancing but dont want to waste my time if this kit is ruined.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Storage of Test Kit
    It's likely just fine. If you have any doubt running new tests, toss and reorder a set of replacements. It's not worth the risk.
    Welcome to the forum.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    See the Taylor article on Recognizing a Compromised Reagent.
