Thread: Vent for the sink
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Vent for the sink
    I'm planning on building an outdoor kitchen with a built-in sink. We're going to run a 3" sewer line to drain the sink so we could maybe later tap into it to build an outdoor bathroom. How should I vent the sewer line if the counter top is the tallest point?
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Vent for the sink
    I'd use an auto vent similar to these http://www.plumbingworld.com/airadmi...autovents.html
    Home Depot carries a version of it. They are suitable for low flow situations like sink drains, and you can add a normal vent when you build the bathroom. Otherwise you'd need to get the vent in the air to avoid odors.
    A studor vent is the way to go. It can be mounted in the sink compartment and will provide proper vented for the sink without the smell.
    Brad
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    oops, forgot the follow-up!
    I got the permit from the city, and after describing the set-up to them, they required that I use a "studor vent" like Bigdawg suggested. We have the line installed and back-filled, but progress will be slow due to a recent knee injury. And besides, I still don't have the deck in yet!
