Thread: A new product I ran across and thought you might be interest
    Arizona
    924
    I ran across this product while surfing the net and thought some of you might be interested.
    http://www.thecirculator.com/home.php
    I have an inground cleaning system which I think helps tremendously with the circulation of my pool. I'm thinking this product could turn any pool return system into a better circulated and cleaner pool, much like an inground system.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Round Rock, TX
    529
    How does this affect the circular motion of the water? I thought that you were supposed to have all the jets pointed one way to get a circular motion of the pool water. Is that to just aid in the circulation, which would not be needed with these devices? I wonder how well the skimmers will work if this circulation is not there.
    It does make since that you get better dye dispersal with these devices.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    New Jersey
    51
    Ok, I'm a bit confused how this device makes filtering faster.
    Water filters at the flow rate of the pump, and this device just churns up the water.
    The old "Gimmick Sense" in tingling !!!
    Might be good for dispersing Bleach faster though
    Guest
    I have used devices similar to this in salt watet aquariums for increased circulation and they have clogged with calcium deposits and stopped working in a short time. I suspect the same thing could happen in a pool. IF your pool was not well designed and does not have good circulation they might be useful but a good daily brushing will accomplish much the same thing, IMHO. I would also be concerned on how much backpressure they intorduce into the system. From the video on their website it looks like it aerates the water quite a bit. This could cause pH to rise.
    Waterbear, I assumed the air was added so you could 'see' the flow in the videos... Or perhaps the returns really do add the air to give the illusion of higher pressure and flow?
    I think swimming daily would accomplish the same thing for free!! If you were that worried about circulation when adding chems, you could do as someone else suggested and brush it in!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
