Thread: Taylor pH test - time to read results
    Hi,
    I have noticed that when measuring the pH with my Taylor kit, that after the initial reading (10seconds or so) if I let the sample sit in the tube over a minute or more, the sample darkens towards the higher Ph range. I assume this is normal and readings should be taken immediately ?
    thanks !
    16 X 32 wooden frame with aluminum braces in ground pool. 3.6ft shallow end, 8.5ft deep end. 22,000 gallons. Pool constructed in 1976 in Chicago area. Mechanics: 1HP hayward super pump, Jaccuzi sand filter, Hayward SWG, and Raypak 2100 heater. No main drain (capped years ago) 3 jets, 1 skimmer. Liner replaced May 2013.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Taylor pH test - time to read results
    You are correct. You wants use the reading taken immediately.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
