Thread: Waterfall stone mortar leaves residue on tile
    Jul 2015
    Williamsville
    1
    I'm a newbie to this forum. I don't have a pool but my sister does and I am trying to help her out. She has large rocks/stones piled up in the back of the pool with a waterfall. There is a scaly, rough, white material that has built up on the pool tile directly under the stones that appears to be wash out from the material holding the stones together. She has tried many different products like acids and CLR but nothing has helped. Can anyone recommend something that could remove this?
    Thank you
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Waterfall stone mortar leaves residue on tile
    Diluted muriatic acid should remove it. Start at 10 to 1 and work up as needed.
