Results 1 to 12 of 12
Thread: SWG reads "Cold" in Summer
    Jul 2015
    Birmingham, AL
    39
    Hi,
    Anyone ever have their SWG display read "Cold" when your water is not cold, ie summertime, and so it doesn't produce chlorine? I have an aqua rite SWG that was installed in 2010.
    Installed 2010: 18X36X6ft 29000 gls, SWG, Vinyl Liner, Sand Filter. 2 skimmers/returns, Polaris cleaner aka Arthur, Heater
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SWG reads "Cold" in Summer
    That would point to a problem with your temperature sensor in the SWG. The normal temp sensor cut off for SWG to run is 50 degrees Fahrenheit. How long has it been since you have acid cleaned the cell?
    Isolated Spa - 345 Gallons
    Jul 2015
    Birmingham, AL
    39
    Quote Originally Posted by JVTrain View Post
    I never have...never looked that bad since directions seemed to be cautious about it. Has that fixed it before and how did you do it? The weird thing is the temperature reads correctly on the display and it will even work fine after unplugging it...then you check on it after awhile and it says "Cold" with no chlorine even though it says the water temp is 88 degrees. I cannot figure this one out.
    Feb 2014
    Central Minnesota
    5,080
    That sounds like a call to support. If your temp is reading 88 and it's reading cold, the temp sensor is not likely the issue. I would call Hayward and get suggestions from them. They're usually pretty helpful if you get a good person on the line.
    Cleaning is pretty straightforward but if it doesn't look like you have deposits on the cell, it may be fine. Check the owner's manual if you want details on cleaning the cell.
    Jul 2015
    Birmingham, AL
    39
    They said the same thing you did that the temp sensor is bad and to replace the cell. I wonder if an acid clean would do it though.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    That cell is 5 years old ish. Getting toward the end of life for most cells. Can't hurt to use a diluted acid bath and see if you can squeak a bit more life out of it.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jul 2015
    Birmingham, AL
    39
    Yeah, I called them back to get a 2nd opinion and he said to try the acid wash first too. When I unplugged the cell, the temp went down to 77 and then back up to 91 when I plugged it back in...not sure if that means anything,but I will try the acid clean and update here. Do you know what the temp sensor looks like so I can make sure I clean it good? Thanks very much for your help.
    Jul 2015
    Birmingham, AL
    39
    Anyone know of a better option to plug the end of your t-15 cell when cleaning it? I tried a 2in plug but it leaked and don't want to buy the Hayward cell stand. Thanks
    Jul 2015
    Wall, NJ
    9
    You don't need to plug it. Put the cell on its end in a bucket and only fill the bucket until half the cell is submerged. Acid clean that end and then turn the cell over to clean the other end. Don't worry about the cord, it's water tight.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Other option is cover end with plastic wrap help in place with a rubber band, then stand it up in a bucket. Then carefully fill with diluted MA, let is soak for about 15-20 min. It should stop bubbling when done. Be careful emptying it. The rinse by blasting water through it.
    chiefwej
    Jul 2015
    Birmingham, AL
    39
    Quote Originally Posted by chiefwej View Post
    That sounds good...does it leak when you do that or does it hold for the 15-20 minutes? Reason I ask is I want the top part to soak good where the temp sensor is, but today the diluted MA kept leaking out the bottom.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Before you fill it with MA, test it by filling with water. That way you will know if you have it leak proof.
    chiefwej
