Thread: Pool Pump Gauge has water in it
    Jul 2015
    Kuna, ID
    1
    We have a hole in our inground pool liner. We are waiting for the new one to come in but still running the pool half full till it does. We were gone for a few days and a storm rolled through while we were gone. I went to check the pump pressure, noticed it was a little over 10 which is normal but there's water in the gauge. Is that normal? We do not have the skimmer basket running as the water is too low for that so water only runs through the drain in the bottom of the pool. Thanks for your help!
    22,542
    Re: Pool Pump Gauge has water in it
    While it's not normal, it's pretty common. While having water in the gauge doesn't really hurt the accuracy of the gauge (until it freezes) it should be dry.
    You can remove the gauge and see if you can dump the water out of it. Or you could just buy a new gauge since they're pretty cheap. If you're going to buy a new one you should get a 0-30 psi model.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Every single gauge I ever bought would eventually have water in it. Did not affect accuracy, readings stayed normal.
    I wonder if the fact that the water has a coctail if various chemicals in it has to do with it, as the water possibly corrodes something that prevents it from going where it should not.
    Unless I forgot to remove it before the freezing seazon (dies instantly) such a gauge usually would serve me for 2-3 seasons (I specifically kept a bad one as a dummy plug for using during the freezing season in my AGP).
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Here is a great replacement gauge, if you should go that route.....
    Rear Mount:
    http://tftestkits.net/Pressure-Gauge...Mount-p78.html
    Bottom Mount:
    http://tftestkits.net/Pressure-Gauge...Mount-p77.html
    Excellent quality gauge.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
