Results 1 to 8 of 8
Thread: I pierced the side of my Intex 15' x 48" - how do I properly patch?
    christopher_c's Avatar
    Jul 2015
    Los Angeles
    8
    Well I was being stupid today. Only our 2nd time in the pool and I grabbed my surfboard and was messing around with friends, trying standing up on it - it shot out from underneath me and pierced the side of our pool. One of those stupid moments you feel like a kid again and could reverse time.
    Anyway, I quickly grabbed some duct tape to keep the water from flowing out. It's kind of doing the job for now, but I don't think it'll last.
    The tear is about 16-18" wide.. pretty big.
    I see I have some patch stuff that came with our pool, but none of it is wide enough. There are 3 different patches that have the pattern of the inside of the pool, with different colored backs. I can't figure out what those are for, or how they are different from one another (wasn't clear to me in the manual).
    Anyone have any suggestions? I wondered if I could actually "stitch" the tear so it doesn't continue to tear wider?
    Is there a way to patch this without emptying the water?
    Thanks for any tips.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: I pierced the side of my Intex 15' x 48" - how do I properly patch?
    Surfboard...in the pool...and I thought I saw it all
    For example, this
    Vinyl Liner Repair Kit - Pool Supplies Superstore
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Jul 2014
    Oakbank, Canada
    389
    Your local pool store will most likely sell patch material large enough.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2015
    Los Angeles
    8
    Thanks for the suggestions - going to head to my local pool store tomorrow and see what I can pick up.
    May 2012
    Montville NJ
    545
    Quote Originally Posted by morzh View Post
    When we were kids, my neighbor used to practice rolls in his kayak in his pool. We had a cheap foam core surfboard and used to put it in the water on one end of the pool, step onto it, ride it across the pool, and then walk off of it when we got to the other side. But then he had a plaster in ground pool, nothing was going to poke a hole it in.
    As for the OP, that hole should not be too bad to patch. Luckily it is near the waterline, and not down near the bottom.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    I've had my surfboard in the pool many times... practicing laying on the board and pushing/jumping to a squat. Thankfully the pool is plaster so I have to worry more about the brick coping scratching my surfboard than my board putting a hole in my pool
    I'm only a kid at heart, to say the least, so I need to practice in order to stay in shape for when I do have the chance to catch some waves.
    Good luck with the patch Christopher.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Jun 2012
    MA
    347
    You should let some water out to below the tear. It will be easier and patch better if it is dry.
    May 2015
    Cape May/New Jersey
    30
    Since it's at the top, there isn't a great deal of pressure compared to a bottom rip. I tore a 3 inch tear at the bottom of mine. I didn't trust just a normal patch for 15,000 gallons of water pressure.
    I bought a roll of 4ft x 2ft 27 mil clear vinyl. I then did 3 layers on each side. Starting with 5 inch, then 8 inch, then 12 inch pad. So that's a total of 6 patches (3 each side). Yes that sounds like a bit overkill,
    but that's a lot of pressure on the bend from bottom to wall.
    After re-setting up the pool this year from a winter storage, that is the only spot the DOESN'T leak lol
