Thread: pump dead - temp solutions?
    Feb 2013
    Dallas, Tx
    10
    So, my pump finally bit the dust (not totally unexpected) and I have contacted a couple of local pool stores to come out and get estimates for a new pump and filter system. In the meantime, is there anything I can do to fight the inevitable swampiness coming in the days ahead?
    TIA
    13.5K, IG plaster, 2x 100sf cartridge filters, VALPAK pump V38-130 1.5 HP, Polaris 360 cleaning robot.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: pump dead - temp solutions?
    Maintain adequate FC for your CYA and mix it with a good brushing. People have survived over a week that way. Is your robot still working? That'll keep things mixed up.
    Feb 2013
    Dallas, Tx
    10
    Sadly not. Pressure cleaner won't do much without pressure
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    buy a cheap sub pump and let it run in your pool to keep the water moving.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Add bleach to maintain FC, brush it and swim around a little and there will be no swamp. Chlorine prevents algae not pumps and filters. Keep it like halfway between target and shock level for your CYA, Chlorine CYA Chart
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Hook a sump pump up and set it on the stairs to keep some movement going. Keep a little extra liquid chlorine in the water, and brush 1-2x/day. You should be able to manage a few days on that
