Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Help my husband keeps getting a rash from the pool.
    Jul 2015
    Staten Island/New York
    16
    I don't know what to do. I have had my pool since I bought the home about 14 years ago. It was here when we moved in so I'm not real sure how old it is. When we opened it up this year it was fairly clean although it had quite a few spiders in it and what looked like white mucous in the pool. We got rid of all of it and set up our filter which is Dalomite. The pool is crystal clear and the levels seem to be fine.
    However, every time my husband goes into the pool he gets this horrible rash along the inside of his thighs and stomach area. He tried changing the chlorine tablets to a different brand and changed the dalomite in the pool. Yesterday he went back in and by the evening he broke out in a horrible rash. We don't know what could be causing it but find it very upsetting as he enjoys being in the pool
    I believe my pool is an above ground oval maybe 10 x 18. I have lived in the home for about 15 years and the pool was here when I bought it.
    38,275
    Re: Help my husband keeps getting a rash from the pool.
    Welcome to TFP!!!
    Please define "levels seem fine". We like numbers
    Odds are with some numbers (really need to be from a Recommended Test Kit) we can ID the problem and offer a solution.
    What is Dalomite? Do you mean you have a DE filter?
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Please add more pool details to your signature as described HERE as it will help us help you.
    Jul 2015
    16
    Yes I would assume it's a DE filter I think Hayward. He checked the levels yesterday and he said both the PH and the Chlorine were perfect. I can find out more from him later.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Most of what I have read says rash comes from high PH. PH should be between 7.2 and 7.8 and measured when FC is below 10.
    Jul 2015
    16
    Thanks everyone. I guess I should find out all the info. I just feel so bad for him. He just started his vacation this week and was planning on relaxing by the pool but with this rash he can't. I will get all the info though.
    38,275
    Here are the numbers we need (not just "in range" or "perfect"):
    FC
    CC
    pH
    TA
    CH
    CYA
    And do not have a pool store do the test, because they are not reliable either.
    If you only ever test pH and Chlorine, then you are missing a large part of the story. Most notably, the CYA which determines the chlorine (FC) levels you need to maintain according to the FC/CYA Chart.
    Jul 2015
    16
    ok. I'll find out although I don't know if his test kit tests for all of that. He was thinking of bringing the water to a pool place to have it tested. Would that be better?
    DFW, TX
    24,485
    Need to get one of these kits, Pool School - Test Kits Compared. I use the TF-100 from TFTestkits.net.
    38,275
    No the pool store would not really be better since we tend not to trust their testing.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Pool stores test for "free" so they can sell you stuff to "fix" your pool. They can and will do more harm than good.
    Please look into buying your own test kit.
    I am guessing there is something in your pool causing your husband's rash.
    You talk about a mucus when you opened the pool. What did it look like? Did it smell?
    Hugs to your pool husband!
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,337
    If you described that to me and said he was in the hot tub, I'd venture to guess folliculitis. Often from Pseudomonas and folks wearing the bathing suit long after getting out of the hot water so it sits on the skin allowing more chance to get into the skin pores.
    I have no clue what dolamite is, but how is the rest of thr pool and how are your chemistry tests using your OWN Reliable-TFP Approved-SuperDuper Test kit? You might not be aware that we don't trust the *free tests* pool stores hand out (for too many reasons to type tonight) hoping you'll be talked in to buying something.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Dolomite is a type of lime that you put down on your lawn to counter acidification of soil.
    Is it possible your putting dolomite into your filter when you should be using diatomaceous earth instead?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jan 2014
    Buckeye AZ
    807
    Eh, you don't need tour husband to go take a picture or write down the filter brand and model. And a pic of the mystery additive you've been putting in there.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jul 2015
    16
    ok. I know you don't trust pool stores but this is what the test revealed. Saturation Idx -2.3. TDS 200. CYA 0. Tot. Chlorine 0.3 Free Chlorine 0. Ph. <6.2. Tot. Alkalinity 10.
    adj. Total Alk 10. Tot. Hardness 313. There suggestion was to add 10.5 lbs of Balance Pak 100 and 2 gallons of liquid shock. Hope this helps.
    Jul 2012
    Tallahassee, FL
    30,464
    IF those results are any where correct your water is a mess
    You REALLY need to get a test kit of your own. Does your pool store sell the Taylor 2006? If so PLEASE buy it NOW!
    Here is a chart to tell you what your levels should be at:
    There is no wonder your husband has a rash. Tell him and everyone to stay out of the pool until you can get it balanced.
    Kim
    Jul 2015
    16
    ok. So he put the stuff in the pool that they gave him and he's now had to bump it twice as the filter keeps dying. Did they at least tell him to put in the right stuff?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by Squeaky347 View Post
    As others have said you really need a good test kit so you can take control
    To add any Chems right, you also should know how many Gallons you pool is, I find this to be a good/easy Calc: Pool Volume Calculator | PENTAIR
    If you need to raise PH, Balance Pak 100 is like $3.00 a lb where Baking soda is about $0.50 per lb and does a great job
    You should do a deep dive into the Links Jason posted
    BTW, Welcome to TFP!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2012
    Tallahassee, FL
    30,464
    I have no idea what Balance Pack 100 is
    PLEASE see about getting a good test kit.
    Kim
    Jul 2015
    16
    Thanks Kim I will.
    Thanks EV. Glad I found you guys. My husband is really stubborn when it comes to certain things. He's the only one that goes in the pool though.
    Anyway, ordered the test kit the TF-100.
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    As shown in this MSDS, BioGuard Balance Pak 100 is nothing more than baking soda (sodium bicarbonate aka sodium hydrogen carbonate). It is used to raise the TA but as was pointed out Arm & Hammer Baking Soda is IDENTICAL and a lot less expensive. So save the money you are spending with the pool store and please get a proper test kit instead.
    10.5 pounds in a 10x18x4.5 foot oval pool (which would be 5300 gallons) would increase TA by 141 ppm which is way too much. I wouldn't add more than 5 or 6 pounds and then retest your pH and TA. If the pH is still somewhat low (say 7.0 or so), you can try aerating the water some to raise it.
    Most likely the TA got low and the pH crashed (got very low) because Trichlor pucks were used and the water was not balanced. Trichlor is very acidic and consumes TA and lowers pH so you need to balance it with other chemicals to increase pH and TA. However, the continued use of Trichlor pucks also increases the Cyanuric Acid (CYA) level in the pool and that makes chlorine less effective to the point where algae can grow faster than chlorine can kill it. So after you get your test kit, you may find that the CYA level is too high and will need to do a partial drain/refill to lower it.
