Results 1 to 11 of 11
Thread: Another BioActive miss
    Jun 2015
    Brighton/MI
    5
    My CYA level has been at about 140 since this spring. So I started to let the chlorine drop from about 8 to 3. At the same time I was adding about 8 oz. of polyquat every other day to fend off algae. When chlorine got to 3, I put in the BioActive. I've kept the chlorine between 2.8 and 4, alkalinity at about 120. Ph at 7.4. It's been 4 days since adding the BioActive and am still at 140. I've been using liquid chlorine to maintain the chlorine levels so I am not adding any CYA. I believe I heard that the first 72 hours was when I'd see the most noticeable drop. This did not happen. Being able to use pucks when on vacation is a big deal for us, but we'll just need to drain.
    So so ill be bringing chlorine back up and do some partial drains. I'm on a well with iron, so was hoping this would work, and trucking in water is more than I care to spend (it would be close to $750 for replacing half the water). Using sequester and Culator now as metal maintenance and will continue to do so. No algae bloom so at least that part is good.
    I hope others have better luck.
    24,000 gallon IG vinyl pool
    DE filter
    single speed pump 1 HP
    refills from well
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: Another BioActive miss
    Thanks for the update. As you have probably read, several folks have tried this with less than stellar results.
    Curious though, how did you measure the CYA?
    Divin Dave,
    Jun 2015
    Brighton/MI
    5
    Half and half pool water and tap water. Came out at 70 (x2=140). Using a Taylor test kit. I hope it is a simple multiplication. Did it the same way for a couple months.
    DE filter
    refills from well
    Jan 2014
    Buckeye AZ
    807
    What's your water temp?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    chlorine is too high from what I have read. It seems to work best, closer to 0 FC.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Seadog, this will only get you 8,000 gallons per filter, but this pre filter seems to do a decent job reducing iron on the way in:
    Amazon.com : Pre Fresh Garden Hose End Water Filter all purpose, pool, spa, hot tub, pets, car wash : Garden Hose Parts : Patio, Lawn Garden
    I'm on well too so know your pain Just so you know, plumbing an outdoor spigot to your water softener is long-term cheaper than trucking water, though even with a dual tank where one regenerates where the other is filling I'm not sure you can do major water changes without pausing for regeneration. For top ups or small changes, though, its great!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2015
    Brighton/MI
    5
    Thanks for the replies. Water temp is 78. I agree FC was on high side, but was hovering within the range the instructions stated. I couldn't get myself to bring it down to zero.
    swampwoman..thanks for the advice and filter options. I actually do have dual tank softener so a new spigot is probably what I'll do. I had not thought of that.
    DE filter
    refills from well
    30,431
    No, it DOES NOT WORK....it's that simple. We need to stop patty caking this product and tell it like it is. It is a failure and any other description is bogus. Please don't continue to coddle this product.....it is a phony.
    Mar 2007
    San Rafael, CA USA
    12,082
    And now we have this thread with a disaster of Bio-Active only doing part of the conversion so while this person let the FC get to 0 the conversion went to ammonia and partially degraded CYA leaving a HUGE chlorine demand (many hundreds of ppm FC). This is even worse than not working which is just a waste of time and money for the product. This is where it costs more -- much more -- than the product itself to fix the situation -- several hundred dollars minimum.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Sea dog, I think you'll enjoy your pool life more if you plumb that spigot...it will take time, but you'll be able to get that iron diluted down. But just so you know, I still get trace amounts out of the softner so its not a 100% solution, though its the best one I've got
    Re bioactive...^i wish they'd have tried to dial in this concept more before rushing to market...but there is one positive thing to the whole Bioactive introduction, however disastrous: its existence has forced pool stores to acknowledge inadvertently the cya:chlorine relationship, and to more readily tell customers their cya is too high. Maybe one day they'll lay off peddling pucks
    ChemGeek, a long time ago we joked about bottling this bacteria...maybe you should offer to study up and revamp their product so that it actually works in a pool environment...in exchange for half the proceeds
    That company deals with AG and water mgmt and might have benefitted from more knowledge about all the variable of products used in pool water. Eg. How would phosfrees enzymes react? How many pools have trace copper that kill off the bacteria? I'm sure there are reasons that what's working in a lab isn't working in the field...
    Helpful Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Trying to get bacteria to behave in an open uncontrolled water environment is like herding cats. Had they focussed instead on just releasing concentrated enzymes into the pool, they might have had a lot better control over the results. Enzyme products exist today and work well for what they do. Having some that worked for degrading CYA is what is needed, even if it required temporarily getting the FC low or to zero or adding chemical at night with no sunlight, etc.
