Results 1 to 7 of 7
Thread: Routine Chemical Additions...
    Jul 2015
    Pittsford, NY
    32
    I just moved into a new house, and was looking for advice on a weekly chemical plan. I have an inground, 17,500-20,000 gallon pool. Most shocks say on the bag to add one bag weekly per 10,000 gallons of water, however, this site suggests that if FC is kept in spec, shocking isn't required.
    What maintenance schedule do you guys suggest to maintain clear water all summer? Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Routine Chemical Additions...
    This: Pool School - Basic Pool Care Schedule
    Regular shocking is not required. Five years open 24/7 365 days a year and never gone green. Never shocked, either. Coincidence? I think not.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Welcome to TFPC!!
    Here is your first assignment: Pool School - Basic Pool Care Schedule
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,272
    Welcome to TFP!!
    Well they gave you the suggested schedule. Do you have one of the Recommended Test Kits?
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jul 2015
    Pittsford, NY
    32
    Thank you all for the quick responses. I have read up on the beginner articles thus far, and they have helped. I also have the TF-100 on order. I understand the test and adjust chlorine strategy. I know it won't take very long, but I imagine there will be days when I don't have time to test the water. And when you are on a solid schedule, is it necessary to test every day, or do you find the right volumes of chemicals that you add every week, and you know will be effective?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You will almost always need to add bleach on a daily basis. Unless you have a SWG. But as you get used to your pool you can anticipate it's needs in that respect. I get up a few mins early just so I can stand by the pool and admire the invisible water.
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by AJC9725 View Post
    Once a week? Not likely. But as others have hinted once you learn the demands of your pool you can probably get by with every 2-3 days. In that 2-3 days my PH may drift from 7.2 up to 7.5 ( I keep my PH lower due to high CH, but that's for another day down the road for you at this time). TA may drop 5-10 points based on adjusting the PH, but that too is a range, not an absolute value. Same with FC. My CYA is 60 (live in AZ with 330 days of sunshine and extreme heat 4 months of the year so I choose to have a little more CYA). My normal FC range is 5-9, 5 minimum. I bring it to 10-11 when I add and know in 2-4 day it will drop to 6-7.
    This works for me, you too will probably find a rhythm. If you check every day or every other day for a while you will learn your pool. Fun to guess beforehand what the numbers will be...
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
