Thread: How to remove and replace Hayward CCX1000V Air Relief Valve?
    Jul 2015
    College Station
    1
    Hello all, I'm new here with a question as my first post. We have a new pool and I am looking forward to doing my own maintenance, and hopefully helping out others in the future.
    The Hayward Air Relief Valve (CCX1000V) on my cartridge filter is leaking. Does anyone know how to replace it? More specifically, do I need to remove the entire Air Relief ASSEMBLY from the filter housing, and then remove the valve from the assembly, or can I just unscrew the valve itself? Given it's all plastic, I don't want to chance breaking anything. Thanks for any advice.
    TXSimple
    Jun 2014
    15,153
    Re: How to remove and replace Hayward CCX1000V Air Relief Valve?
    Hello TXSimple! From the looks of this image: Hayward CCX1000V Manual Air Relief Valve, it would appear the entire valve should be able to be unscrewed/removed. You can shop at local pool stores to obtain a replacement O-ring which may resolve your issue unless you believe replacing the entire valve is required. I suspect if you order a new valve it should also come with its own O-ring.
    By the way, welcome to TFP! glad to have you with us.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The top tank needs to be removed to access the locking nut on the bottom. The air relief assembly parts are not available. Just the CCX1000V.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2014
    15,153
    Thanks for clarifying HP!
