Thread: Bleach question
    Jul 2015
    Leland/NC
    24
    Bleach question
    The bleach I have is a store brand bleach thar says 7.86%.
    But I see alot of people reference 6% bleach.
    I will adjust using pool math....but was really just wondering why such a difference in %
    Even the clorox brand was 7.86% in my store. Maybe it's a regional thing?
    Intex metal frame 12x3 pool
    Installed July 2015, 1718 gallons, Krystal clear 530 gal per hr filter pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Bleach question
    Yep, different regions different rules and different percentages. It varies from 6 to 8.25.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Bleach question
    Recheck the label. It should say 8.25% sodium hypochlorite. It also says "yields 7.86% chlorine". Everybody on this site would say your jug 8.25% bleach. And PoolMath expects you to use 8.25% as the bleach percentage, not 7.86%
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jul 2015
    Leland/NC
    24
    Re: Bleach question
    Quote Originally Posted by epro05 View Post
    Ahhh I see....ok I didn't realize that. Just checked my bleach and you are right. Let me go adjust my pool math. Thanks!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Bleach question
    You should also learn to read the date code on your bleach jugs. I don't buy bleach that is more than 30 days old. This link should help you with that.
    http://www.troublefreepool.com/threa...asure-Strength
