Multiport Valve lid leak
Did you see any cracking or other visible damage to the lid? If not, consider reinstalling same spider gasket. Be sure when tightening down the lid to tighten very evenly, each screw just a little at a time and don't over tighten either.
So if i take it off and compress the spring i can get to the o ring in the handle shaft to replace it? It is weird now that I replaced the spider gasket I get some leaking from the handle on start up then it generally stops after running.:confused:
