Thread: beware your ladder bricks!
    Jun 2015
    collegeville, pa
    20
    We recently battled a mysterious algae issue with the wonderful help of this forum. We couldn't really find a source at the time despite checking the usual suspects (edges of liner, behind ladder, under ladder mat, skimmer box, pool toys, solar cover).
    After great results since our SLAM, we had some sediment returning again! We were so frustrated!
    We pulled the ladder, and I noticed that the bricks that we wedged into the back of the ladder in the spaces provided, and as instructed by the manufacturer, were a little slimy. It dawned on me that the rough surface of the bricks, and the nooks and crannies that they hid, were prime algae zones.
    The only way for me to get the bricks out was to drill access holes on the front of the ladder rungs, and push the bricks out with a screw driver inserted through those holes.
    When the bricks fell out, there was 1/4" of algae having a party on each brick. Every other surface of our pool was spotless, but these bricks were hiding a field day for algae growth.
    So, we got rid of the bricks and will deal with a ladder that wants to be floaty. I drilled circulation holes all over the ladder in a nice symmetric pattern. After scrubbing down everything and checking our levels, I think we may be good to go and have avoided any need to do another SLAM, but we'll keep a close eye on it.
    Anyways, all that to say what you all probably already know.... Watch those bricks.
    14,500 gallons, 15x30x52" AG "Wilbar Escalade, Rolled Steel Wall", sand filter "micro media 1 hp filtration system" (single speed pump), aqualuminator underwater light, aqua comfort heat pump, pool installed spring of 2014, test kit = FAS-DPD, filled from city water supply
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: beware your ladder bricks!
    Something like this would be nice: Problem Found and Ideas needed
    Jun 2015
    collegeville, pa
    20
    Sorry, ladder back in already before I thought to take any pictures. The back of my ladder is similar to what you just linked but without a cover. Just open pockets where pavers/bricks are intended to wedge in very tightly.
    We swam without any weight on the ladder today, and really didn't notice any problems with the ladder floating. We did a nice job with the deck connection (bought an aluminum sleeve rather than the plastic it comes with, and through-bolted the connection rather than a set screw) so I think that helps.
    Our FC dropped big time today, I think as a result of stirring things up during this discovery. We have enough liquid chlorine on hand to spike above target, but not to SLAM level, so we'll have to report back again tomorrow. My hope is that with the source removed, we'll recover without losing more of our swim season.
    More soon
