Thread: moving legs
    Jul 2015
    Belleview, Florida
    15
    moving legs
    OK I got all 26 pavers flush and level with the ground and under each leg , made sure they were all straight, pool is now filled and every so often one moves. Please tell me is this normal and has anyone else experienced the slight bend inward of where the T connects to the legs. Nerves are shot and frazzled !!!!!!!
    Intex ultra frame 26' x 52" AGP
    14,677 gallons
    Krystal Clear model 633T Filter Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: moving legs
    I had to move the legs around a little to get them settled into the right spot.
    May 2015
    Southern Illinois
    49
    Re: moving legs
    I have the same pool on pavers as well and all of mine look like they are bending toward the pool. The legs get to where they need to be under the force of the water.
    26' Intex 17k gallon above ground pool. 3000 GPH intex sand filter. Taylor Tech. k-2006 Test kit.
    Jul 2015
    Belleview, Florida
    15
    Re: moving legs
    Thank you so much pooldv and dustbin3 for your input. If I knew how to post my pictures....is the T part from where it connects to the legs bending in on yours ? It did on mine but not too much
    14,677 gallons
    May 2015
    Southern Illinois
    49
    Re: moving legs
    Yea, it looks like the pool pudged out and the legs are stretching to hug them tight. I wouldn't worry about it, if the legs aren't where they need to be they will definitely move on their own but as long as they are all touching and sturdy it will be fine.
    Jul 2015
    Belleview, Florida
    15
    Re: moving legs
    Thank you so very much !!!!!! I feel safer about letting the legs move on their own instead of me trying to move them as I have read some have done ( I'm not that brave ) Yes they are all touching,sturdy , and so I will do my best to relax
