Results 1 to 9 of 9
Thread: Can't hold chlorine
    Can't hold chlorine
    I am having a huge problem holding choline. Basically all the other numbers are fine. No algie to speak of. I have added at least 6-7 lbs of Powder Power Plus over the last two days and the tests barely shows .5. I have been experiencing this problem all summer. Pool store is as puzzled as I am.
    First time to forum, so if info. is needed, please advise. Thanks.
    Doughboy 24000 gal., oval, dug in, Zeo sand filter, Hayward heater
    Burt
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Can't hold chlorine
    Welcome to the forum. Got a full set of RELIABLE test results so we can help? How are you testing? We have recommended pool test kits in Pool School.
    38,303
    Welcome to TFP!
    Please post a full set of test results ... Not from test strips or the pool store.
    Likely you have something in the water consuming the chlorine and may have over stabilization problems.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    Welcome!
    Something's eating it - either algae or sunlight. Test results would help, and so would a description of the water. Is it crystal clear, clear with patches of algae, cloudy, milky, green, what?
    If it's just low CYA and the sun is getting it, that's easy to fix. If it's the beginnings of an algae bloom, that'll take a while. Just do what these folks did: Recovering my old inspirational links - Page 2
    Latest test results:My testing: Chlorine 0; Ph 7.0-7.2;TA 100; CYA 75-80. No phosphates. Calcium hardness high.( Leslie's shows 400. I think higher, but not sure. My test doesn't seem right.) Water is cloudy. On a scale of 1-10, about a 5. Lot of rain lately. No metals.
    Leslie's recommendation: hit hard with 5 lbs of Powder Powder Plus. I have used multiple lbs. of PPP in the past, but only lasts a day or so.
    Any ideas?
    Thanks.
    PS I do have a TF100 test kit. Are there other tests I can do with it?
    Burt
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by burt View Post
    The TF-100 uses the best tests there are. What are your test results?
    Support the site
    38,303
    You have the TF-100 ... now follow the ShockLevelAndMAINTAIN Process
    Richard320's Avatar
    Jan 2010
    19,014
    Every pound of power powder adds 3.6 FC to your pool along with 2.6 CH. Your CH is already north of 400, so I'd stop it and switch to bleach. Other powdered chlorines will raise the CYA level and lower the pH and you're already stretching the boundaries with those.
    Look at that link I posted. Scroll through and look at the pictures. Bleach did that. No doubt you'll see reference to SLAM. Pool School - SLAM - Shock Level And Maintain That's the solution.
    Apr 2013
    North OKC Area
    300
    Test FC hourly until it starts to hold FC then double it to two hours, then four. You need to maintain shock level FC which is found in the chlorine/CYA chart.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
