Results 1 to 10 of 10
Thread: Hayward pump ...motor problem
    Jul 2015
    Warwick RI
    6
    I've got a Hayward sand filter and pump with the motor that was supplied with it. Last night the pump was running fine when I shut it down about 10- ran late since I had shocked the chlorine. This morning when I went out to turn it on the motor came on momentarily then stopped. Turned it off then back on again and same thing. The ground fault did not trip. Shut off the switch then opened the strainer basket which was plugged - cleaned that and tried again but absolutely nothing this time. Shut it down again, opened the strainer basket and stuck my finger into the impeller housing ...it spins freely so I know it's not bound up and since it's a direct connection to the motor that doesn't seem to be bound up either.
    I know I have power from the circuit board so it is not anything in the feed line. I unwired the pump from the switch and tied a plug onto and plugged it into a live socket ...nothing. I'll guess it is something to do with the "stuff" inside where the power connection is made to the motor - capacitators etc. I've checked all the 110 connections back there and they are tight. Anyone have any ideas?
    Thanks!
    Jun 2015
    Wildomar, California
    423
    Re: Hayward pump ...motor problem
    Sounds like something inside the motor. Loose connection? The capacitor only starts the motor, it wouldn't turn it off when it is running. A motor that suddenly or randomly stops also could be the heat overload switch at the back of the motor. In that case, check for blockage at the intake in front of the motor.
    Jul 2015
    Warwick RI
    6
    The first couple times I started it today it came on but only for a moment..barely a second. Now there is nothing. When I open the strainer I can get a finger into the impeller and it does not feel clogged and it is spinning freely. I've been over the connections - took them apart and cleaned the spades and redid.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    I do not know this motor but it may have two caps, start and run.
    Plus I would check inside under the rear cover.
    Make sure you disconnect it. Put it on the bench and give it a thorough check under the cover. See if the switch (it might have an On-Off switch there) is OK.
    Look for anything from frayed/charred wiring to cold solder spots, rust/oxidation. If all is clean, locate the caps and see if they both (if two) measure OK according to the label.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Jul 2015
    Warwick RI
    6
    The Hayward model number for the pump is SP2605X7, the motor is an AO Smith C48J2N131B1 and I think the new/current Century number is UST1072
    Jul 2015
    Warwick RI
    6
    I pulled the capacitor out of this and brought to a local shop this morning to have tested....it's fine. Anyone come up with any ideas? If I bring them the motor it looks like 10 days to 2 weeks.....
    Jun 2015
    423
    When you say that it stops, do you mean it just buzzes or goes silent? I should have asked this sooner. That would help us diagnose your issue
    Jul 2015
    Warwick RI
    6
    It was silent...no buzz, nothing. BUT this afternoon I was about to cut it out of the plumbing to get it in on the bench...and decided that before I did that I would try one last thing.. I took the tail off another pump someone had given me as a loaner...which was useless since it was dead....and attached that to the existing motor and plugged it in...VOILA...she lives! I had no reason to suspect a heavy rubberized cord had gone bad so I had vetted the connections at the motor and then put a plug on the existing cord yesterday and got nothing...apparently the flexible wire to the pump has a short/break in it somewhere... Yeah I've burned the better part of 2 days on this BUT it has only cost me 6 bucks so far ...a short piece of 1 1/2 pvc I bought to repair the plumbing if I had to cut this one out and an ice coffee for the fellow at the motor shop who tested the cap for me. The fittings I bought can be returned and should cover the cost of a longer and heavier piece of sj cable...
    Jun 2015
    423
    Excellent. I should have inquired about the noise earlier. Silence equals no power unless the motor is totally fried. Otherwise buzzing is like a bad cap, frozen impellor, bad switch, etc
    Jul 2015
    Warwick RI
    6
    I feel like an idiot not having bypassed the feed wire....I had checked the connections etc and got nowhere ....never dawned on me that the cord itself could have a fault in it
