Results 1 to 12 of 12
Thread: Sparkling water & algae???
    May 2015
    Augusta, GA
    27
    My water is looking great, FC usage seems normal, but there is something that looks like algae accumulating on the bottom of the pool. Unfortunately, when it came up I was going out of town for 2 weeks and had only two days to try and manage it. First I vacuumed out everything that looked like algae. I brought the pool to shock level (12) and maintained it all day. Passed the OCLT, but in the morning the algae had started to accumulate. I vacuumed again and brought it up to shock level. However I was leaving that day so I told the guy taking care of the house to add 1 gallon of bleach if he saw algae (and to brush the algae) and 0.5 gallon if there was none (which is the normal amount I use per day). I left the pump running the entire two weeks I was gone.
    I came home and the pool water is still very clear, but those algae spots are still there. The pH was high at around 8, so I've dropped it down to 7.5. FC was 6 when I got home.
    Do you think this is algae or something else? Any help is appreciated!
    Thank you,
    Jason
    18x33' x 48" deep above ground with sand filter and Hayward pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: Sparkling water & algae???
    Do you have a turkey baster? Use that to get some out. Squirt it out on to a white paper towel.
    What color is it? Was it hard to get up? What does it feel like?
    Kim
    May 2015
    Augusta, GA
    27
    I'll see if I can get some out - it looks to be sort of a brownish color and is very fine. If you brush it lightly it comes off the pool floor very easily and just disappears into the water without making it look cloudy. After several hours it accumulates again, always in exactly the same spots following the same pattern.
    Thank you,
    Jason
    Jul 2012
    Tallahassee, FL
    30,580
    Have you ever added DE to your filter? I am going to post a link to how to do it.
    It might be enough to filter out whatever that stuff is.
    Pool School - Add DE to a Sand Filter
    Just make sure you will be able to be there to babysit it the first little while until you learn how your filter does with DE in it.
    I would still like you to try to get some up just so we can see if we can figure out what it is.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Are they stuck to the liner like they are growing and fuzzy? Yes, it is algae, I have had the same thing, perfectly clear water, no CC. Raise FC close to shock level and keep it there for a week or so and brush daily or twice, especially those spots. Also, clean out behind your light if you have one and under ladder rungs and other hiding spots. Took me about a week and a half to get all traces of algae to stay gone with FC 25 to 28 and CYA 70. We swam every day while SLAMing. Keep your FC a couple PPM above target after you get the algae to stay gone. I go 8-10.
    May 2015
    Augusta, GA
    27
    There seem to be two types - one that is growing and fuzzy and one that starts on the wrinkles and seams of the liner but follows the line/seam and doesn't look fuzzy. I'm heading out to see if I can trap some now. I'll have to head out to the store to get some more bleach before starting a SLAM.
    Thank you,
    Jason
    Mar 2007
    San Rafael, CA USA
    12,082
    Yellow/mustard algae prefers shade and tends to not grow on the sunny side of the pool. If it's all over including on the sunny side, it's more likely to be dirt or pollen. You can use a skimmer sock to see if you collect any material and if you do then it's more likely that this is something getting blown into the pool on the surface and then eventually sinking.
    Oct 2014
    Beaumont, CA
    47
    The dead algae you are vacuuming is too fine for your filter media and is going right through your filter and back into the pool. I had that very same problem, and my solution was to get a Duda Diesel filter bag, it works!! Read this >> Trying out the SlimeBag
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    Mar 2007
    San Rafael, CA USA
    12,082
    Algae vary in size, but common green algae Oocystis is oblong at 2 to 16 microns in size when not clumped so can get through sand filters and barely through some cartridge filters (though usually not when such filters get a little dirty) but not through DE. Usually algae clumps so gets caught in sand filters, but if it's a fine dust-like algae it may not get caught and requires finer filtration.
    DFW, TX
    24,502
    Jun 2014
    Gulfport, MS
    67
    Quote Originally Posted by Spades View Post
    Does anyone see a problem with attaching the bag to vacuum hose adapter and capturing this stuff at the suction side vice the return side? I think this is the same stuff I posted about in my thread and I'm trying to come up with a better way to get it out of the pool vice multiple adds of DE powder/vacuum's.
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
    Jul 2012
    Tallahassee, FL
    30,580
    Some people have talked about "slime bags" and such. I have not had any experience with it. Try a search for it and see what you find.
    Kim
