Results 1 to 9 of 9
Thread: Manual vacuum pressure too strong in fiberglass pool
    Oct 2012
    McKinney, TX
    50
    How do I reduce the amount of suction when I manually vacuum my pool? It is so strong at times that I fear I will be another pole or I have to turn the head to break the seal to move it.
    My pool is fiberglass with only one skimmer. I put the skimmer plate on, fill the hose via the closest return until the bubbles are gone, then attach to the plate. Could I reduce the time I fill the hose, would that help?
    Any suggestions??
    Liberty Pools - Lincoln
    McKinney, Texas - Built Jan 2015
    10,800 Gallons Fiberglass IG; Hayward SP3200VSP; AquaRite T-Cell 3 SWG; Hayward C17502S Cartridge Filter; TF-1000 Kit on it's way
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Manual vacuum pressure too strong in fiberglass pool
    If you have a main drain, open the valve to it to reduce the suction on the vacuum. If you're sending 100% of the pool suction to the vacuum and you have no way to not do it, then maybe start modifying the skimmer plate by drilling a hole in it - start small. Just experiment until you divert enough suction away from the hose that the head doesn't stick to the floor.
    Oct 2012
    McKinney, TX
    50
    No main drain, only the skimmer, so I will drill a small hole to start.
    Thanks!
    30,424
    Do you have any valves on your equipment. They could restrict your flow and reduce suction. Easy Peasy. Got a pic?
    Oct 2012
    McKinney, TX
    50
    Only the valve for the deck jets. Would that lower the suction power?
    30,424
    Got a pic of your equipment? The deck jets will work but I am thinking there might be a better way.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What kind of vacuum head? If it's the kind with brushes, worn brushes will cause excess suction.
    May 2012
    West Columbia,SC
    51
    I too am worried about that. I currently only have one return and one jet (old pool in need of additional leak repairs.) Planning on vacuuming today. I have concrete bottom and fiberglass sides, my only worry being the hose might collapse. Should I be worried? Only have used my robot to clean, but recent outage of pump caused a lot of silt on bottom and want to get that up asap. Just got the last piece yesterday I needed (Skim Vac to attach hose to.) Should I just go for it and see what happens?
    I do have valves, but they have pins put in them by pool guy who put equipment in due to finding out drain leaked and other jet was closed off by previous owners.
    28000 IG Hybrid Pool,Pentair 340039 1.5HP,Sand DollarSD-80,Solaxx Harmony SWG & Robot, Soon to be installed CircuPoolSWG-45,PoolMaster 5 way TK
    (I know,I know what I SHOULD HAVE)
    Oct 2012
    McKinney, TX
    50
    Here ya go...the brass spigot at the top with the hose attached is to drain excess water. I have drilled a hole in the skimmer plate but it doesn't seem to help much if any at all. Maybe it needs to be bigger. The suction is so great that if the hose is kinked it will bend and kinda suck itself together...very frustrating too.
    Last edited by mckinneymagnum; 07-25-2015 at 06:09 PM. Reason: added more info about picture
