Results 1 to 13 of 13
Thread: Tons of debris + constantly tearing filters
    Mar 2008
    El Dorado Hills
    17
    We've had this pool for about 8 years now (previous owner built it). Its very close to a very large eucalyptus tree, the medicinal kind which is also used in flower arrangements. Needless to say, it drops tons of leaves and sometimes small twigs/branches (hardly ever thicker than my pinky finger) into the pool, and lately what seems like thousands of a certain kind of beetle larvae. When we moved in they had a jandy energy filter and manual switching of the jandy valve to clean and just filter. I removed the jandy enery filter and just had the cleaner line coming off the main filter, as I heard those energy filters can break and then drain your pool without you knowing it. I also got a bigger cleaner than what was installed, but still went with a non-booster pump cleaner still with a dual speed pump.
    With all these changes, at least the sweep has been automated, but the filter cartridges keep tearing, and I typically replace all 4 of them every year. I can tell they are torn because I get stuff clogging the inline filter for the cleaner in the wall of the pool, so things are getting past the filter. I just replaced them a couple months ago and I'm already seeing stuff come through the filter. When this happens it seems as if the filters are practically ineffective and the pool gets dirty with stuff floating in the water not getting filtered. It also makes the sweep grind to a crawl as its inline filter gets jammed full of stuff and causes extra work for the pump.
    Every other pool I've seen uses a booster pump cleaner, and I have been wondering if pushing the water on high speed through the filter is whats causing the tearing filters. I've been debating:
    - going back to an energy filter and bypassing the main filter while running the pump on high speed for the sweep
    - getting a booster pump and replacing my cleaner, so I can run the pump on low speed only. Not sure if pulling through the filter would be as damaging as pushing through it.
    I'm not sure what the best option is, or if there is another way to (as automated as possible) have a clean pool.
    Here is a picture of the pool, where you can see the eucalyptus tree in the background:
    In-ground plaster pool
    Hayward C4520BHMB cartridge filter 450 sq ft- 150 GPM
    Hayward Super II Pump 1.5 - .25 HP
    Kreepy Krauly Legend II
    30,415
    Re: Tons of debris + constantly tearing filters
    What is the point of the energy filter and are you using it? Is it installed before your primary filter or after it?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Sounds like you have a suction cleaner which sucks up debris and carries it back to the filter. A booster pump cleaner is a pressure cleaner. The booster pump adds extra water pressure to the cleaner to blow water through the cleaner to pick up debris off the floor into the cleaner bag. Nothing goes to the filter so that would help your situation. Or a robot cleaner would also keep debris from moving to your filter. Or a leaf rake to scoop out sticks first. Is it seasonal or does it drop sticks all the time? If all the time then I would cut it down.
    I don't understand how sticks are getting to your filter in the first place. The skimmer basket should catch them and then the pump strainer should catch them.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    How about adding an inline leaf canister?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Are you sure the cartridges are actually tearing? Have seen the tears in the fabric? Sometimes the cartridges don't seat properly in the manifold and debris can sneak by them. There may be something wrong with the manifold too.
    Mark
    Mar 2008
    El Dorado Hills
    17
    I believe its a smaller filter that's used in the cleaner line that bypasses the main filter. I removed it and don't have it anymore after someone told me they break and if you aren't watching it will run the pump and drain your pool.
    Quote Originally Posted by pooldv View Post
    Its year round. Sticks don't normally make it to the filter, they sit in the bottom of the pool till I fish them out. We have a pressure cleaner, but it doesn't use a booster pump, it runs by turning the pump onto high speed. I've researched the robots a bit, but I don't know how well it would do with the amount of stuff getting into the pool and I'd have to go put it in every day and then take it out. (I've read its not safe to leave it in the pool all the time and the chlorine can cause more damage over time that way)
    These are on the suction side, right? I've used one in the past with a vacuum attachment when it gets really bad after a storm, but without a suction cleaner it wouldn't work automatically.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    aren't skimmer basket and the pump skimmer basket for this?
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Mar 2008
    El Dorado Hills
    17
    Quote Originally Posted by mas985 View Post
    I haven't seen tears in the fabric. Is there anything I should check for in the manifold?
    Quote Originally Posted by morzh View Post
    Yeah. Our skimmer basket and pump basket are normally full of stuff. Maybe I just need to clean them out more often. I currently try to clean out the skimmer basket once a week, but sometimes it goes two weeks. The pump basket gets cleaned out every three weeks or so.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Tears in the fabric should be pretty obvious so that may not be the cause. I would inspect the other parts to look for cracks, holes or pieces missing. Also, there is a very small filter screen that goes on the air purge tube and if that is missing or missing the screen, that can allow debris to reenter the pool. See number 12 below:
    Mark
    Mar 2008
    El Dorado Hills
    17
    Thanks! I'll try and check that out either tonight or another night before this weekend.
    Dec 2009
    Virginia Beach, VA
    130
    Anybody else think that's a sketchy looking diving board to have your kid jumping off of? The slide looks fine but that diving board looks like an accident waiting to happen.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    AprilsZoo's Avatar
    Jul 2013
    100
    Quote Originally Posted by astead View Post
    I think as long as you have the tree you are going to have to resign yourself to checking and cleaning out the baskets *much* more often.
    I check my skimmer everyday, and sometimes more than once, if I know that there is likely to have been a lot of debris blown into my pool (i.e. monsoon season).
    My pump gets a visual "look-see" everyday at the same time as my skimmer, and opened and cleaned as necessary based on what I see-- prob. once every week or so, sometimes longer.
    I'm pretty sure that most people, even those who do not have litter-heavy foliage in their yard, check their skimmer, etc. a lot more frequently than you indicate.
    Could you at least look to see how full they are every day, when you are doing other things in the pool, like brushing, running the net around the surface, checking the chlorine, swimming, etc?
    I would expect that when your skimmer and pump basket are filled with debris, it is harder on your pump and affects your entire filtration/circulation cycle.
    I'm curious: if you aren't seeing any visible tears in the filters, specifically what is it that led you to the conclusion that they are "constantly tearing"?
    🌵 April 🌸
    Some of my posts may be long... but they're *always* worth it! 🙃
    👙 Intex UltraFrame 21' x 52" {~10,000 gal.} 🐠 Krystal Klear 16" Sand Filter 🐳 Pentair Intelliflo 1.5 hp Variable Speed Pump🐬 Borates @ ~50 ppm 🐚 Taylor K-2006 test kit & SpeedStir🌀
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by jobondur View Post
    +1
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
