Results 1 to 10 of 10
Thread: so how many have done their own IG liner replacement
    May 2008
    mo kc
    11
    so how many have done their own IG pool liner replacement
    i have a 18x36 pool with hopper bottom
    deep end is 6'
    stairs are the bucket type not lined
    i'm a very hands on kind of guy and
    i'm 99% sure i could do it
    but what do i need to look out for
    and were should i order the liner from
    20x40 In-ground Vinyl liner with no swg yet and no heater approximatley 25000 gals
    30,403
    Re: so how many have done their own IG liner replacement
    Welcome to the forum.
    I've done it twice. Both times, I could've used a little more help.
    On a pool your size, 6 people is not too many. If you can round up that many, you'll have little problem. Patience is important and do it on a fairly warm day so you can work the liner. Plan on most of a morning or a little more.
    Like all jobs. successful prep will yield successful results.
    It may be pretty easy to find an exact fit for your pool if you know manufacturer and model. If you have to order a custom liner, make your measurements and diagrams precise.
    I cannot help you as to the best place to order the liner......perhaps a local dealer would help you or you can certainly find resources online.
    May 2008
    mo kc
    11
    do not know manufacturer
    the pool is like 13--20yr old
    The most important thing is getting perfect measurements. We would never order a liner without doing custom measurements. Go to this page: http://triac.com/measurements.php - and download the proper measuring sheet and fill it out in full, with every measurement accurate to about 1/8 - 1/4". Our guys spend 1-2 hours doing a set of measurements.
    You also should get yourself a few feet of T-Bead or Liner lock from a pool dealer. When you're putting in the liner this stuff will help to hold it in place in the corners and other tough spots.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Of course, you may need to redo the bottom. It's shape is critical to the liner fit, and you may need new wall foam, if its used in your market. Is your pool a "kit" pool - steel or polymer walls?
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    May 2008
    mo kc
    11
    polymer walls yes
    foam yes
    floor good as i can tell
    i just got a quote for $2500
    and just got one for just the liner for $1000
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    personaly id pay someone to do it... Its not like changing a pump, or putting in a new filter. There are many things u need to worry about. proper gaskets, measurements, you will need a liner vac, ive seen a shop vac used but usually on smaller pools. Do you have ground water? (water under the pool) even though im in the business im all about ppl savin a few bucks.. but a job like this can end up causing u more money down the road. atkleast if you hire someone and something doesnt workout... THEY are responsable...
    $2500.00 isnt a bad price.. its more then i would charge, but im sure u can find someone who can do better.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Mar 2007
    San Rafael, CA USA
    12,082
    FYI. On another forum here, I saw this link to instructions on installing an in-ground pool liner. I don't know if these instructions are any good.
    Guest
    Like any DIY project YMMV! For example, I just redid my bedroom floor with wood flooring. Seemed like a real no brainer. Figured out pretty quickly that I was in over my head.
    Luckily I have a neighbor who is a carpenter and who owed me a favor!
    The floor looks great, btw!
    I have had customers that have replaced their own liners and others that got into trouble and eneded up having to pay to get the job finished (and I suspect they ended up paying more since it was a 'fix it' job!)
    Heckpools raises some very good points that I would carefully consider all of them before attempting the job yourself.
    budster's Avatar
    Dec 2008
    272
    There are, indeed, concerns about a good fit, and those who do it for a living, know a lot of the tricks that you will not. Thus, I'm not 100% in favor of a DIY project.
    However, if you know for sure the manufacturer of the pool kit, and that it was installed per their specs, you can often get a liner made for that pool kit. Since it's polymer, do you know the manufacturer, or have any clues? I'll try to steer you.
