Thread: Intex Sand Filter, 3000 GPH
    Jul 2015
    Peterborough Canada
    24
    Does anyone have a review/recommendation on the Intex 28651EG 3000 GPH sand filter?
    I have an Easy Set 12' x 30" and would like to use a sand filter instead of the 1000 GPH 637R that I "upgraded to". My intex solar heater mat appears to really slow down the flow, basically to a trickle, and everything is installed correctly.
    Could I get away with the 2100 GPH sand filter (I'd like to be able to vacuum), or is bigger better when it relates to pump/filter combos?
    Thanks in advance!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intex Sand Filter, 3000 GPH
    I have the 2800 GPH model and love it. I would say for vacuuming suction side that the 3000 gphmahbebetter, but cannot say for sure. I have a return side vacuume and a pool blaster max I use.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
