Thread: Overriding / temporarily disabling Aqualink schedules
    Jun 2013
    Austin, TX
    27
    I'm going to be adding some CYA to my pool and I understand I need to run the pump for a while to allow it to dissolve. I can turn it on manually, but every time a schedule kicks in, it will take over and lower the speed or turn off the pump before I want it to. Is there a way I can override/suspend it?
    I guess I could just put it in service mode for a day if I can pick a pump speed while in service mode.
    15k gallon, IG plaster pebble surface, single speed filter pump, sand filter, Polaris 280 cleaner w/ PB40 booster, AutoPilot Nano+ w/ RC-28 cell.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,178
    Re: Overriding / temporarily disabling Aqualink schedules
    No need to run the pump 24/7'to add CYA. Put the CYA in a sock and suspend it in front of a return, or place the sock inside of a skimmer if it doesn't block the whole thing. Let the pimp run as normal.
    Support the site
    Jun 2013
    Austin, TX
    27
    Well my CYA was way low so I wanted to get it dissolved as fast as possible, I thought running the pump non-stop would get it dissolved faster. I've read stuff saying don't backwash for 72 hours after adding it to give things time to dissolve. Good to know I can do the sock thing when doing regular maintenance.
    And I'll let that "pimp" run as nomral if they want to as long as they leave my family alone. har har har
