Thread: Pool puck manufacture
    Are all pucks di-chlor or tri-chlor?
    13000 gallon fiberglass, cartridge filters pentair Intelliflo Variable speed Programmable Pump separate booster pump solar panels on roof
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool puck manufacture
    There are no Dichlor pucks that I am aware of. Dichlor is in granulated form. Pucks are either most commonly Trichlor or sometimes Cal-Hypo. The Cal-Hypo usually has some binders in them since compression alone is not enough to hold them together.
    Thank You Richard
