Thread: Partial pool drain
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Partial pool drain
    Soon I plan on doing a 50% pool drain to get my CYA down (everything else is right on). It seems pretty straight forward but is there anything of concern I should watch out for? What about the filter, obviously it will be off but will it need re-primed before starting it again?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Mod Squad JohnT's Avatar
    SW Indiana
    9,089
    Re: Partial pool drain
    Use the pool pump to get down to the bottom of the skimmers, then if you have a main drain and can shut-off the skimmers, keep going until you lose prime. You won't get to halfway without an external pump with most pool systems.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I have a 2,000 gph separate pump that I plan on using, sorry I should have mentioned that.
    Polaris 280 robot
    Pool Calc user
    sammm's Avatar
    North Richland Hills, TX
    257
    Make sure you have enough hose on your sump-pump to get the water away from your house and your downslope neighbors (don't ask how I know :P )
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Jan 2009
    Cupertino, CA
    1,966
    Some areas have restrictions about draining (and backwashing for that matter).
    Where I am, I have to drain into the sewer, not the street or ground.
    (But I can backwash onto the ground, as it's a relatively small amount of water.)
    --paulr
    BBB "Intermediate Swimmer"
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by PaulR
    --paulr
    That is the same in my area. I have French drains that I believe are connected to the sewer because there are no drains to the curb/street so that is where I plan on draining it.
    Polaris 280 robot
    Pool Calc user
