Thread: Completed 2/3 drain, CYA down to 100.
    May 2014
    Maryville, Tennessee
    2
    Long story short, Wife was having problem with Algee, I ran the test on the Taylor K-2006 and found CYA was literally off the charts. At the 1.8 mark on tube I lost the black dot. i just finished draining and refilling 2/3 of the pool and the latest test comes in right at 100. I can't say I'm surprised.
    I just got the water level back to normal, these are the initial readings.
    FC - 1.2
    PH - 7.0
    TA - 70
    Kevin B, Maryville Tennessee.
    13000 gallon, 16x32 Oval 4' deep AG.
    Sand Filter and Turbo King 2Hp pump.
    Taylor K-2006 Test Kit.
    38,246
    Re: Completed 2/3 drain, CYA down to 100.
    Welcome to TFP!!!
    The best path forward would be another 50% water replacement and then following the ShockLevelAndMAINTAIN Process to eradicate the algae.
    And then making sure you are not adding chemicals that are raising the CYA level any more.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    I am glad you have a good test kit. You will have your pool clear and balanced in no time!
    Kim
    May 2014
    2
    Followed jblizzle's advise and did another 50% drain. CYA is down to 60, that seems manageable and I can work with that. After the pool was filled, adjusted Total Alk to 100, and PH is 7.4. Water is clear.
    I used 4 1-lb. bags of Cal-Hypo and free chlorine is now 10. Combined chlorine shows zero. Not at the poolmath SLAM level but at least we have working chlorine again. I also have 2 1-gallon jugs of 10% sodium hypochlorite. My next questions is can I add the sodium hypoclorite in with the cal-hypo to bring the pool to SLAM level, or should I just stick with the Cal-Hypo? Thanks all.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You can add the liquid. The prohibition on mixing forms of chlorine is generally in a confined space or in the pool quickly together. Th CalHypo you added should be well mixed now, so you can add other chemicals including liquid chlorine.
    Support the site
    38,246
    SLAM away!!!
