Results 1 to 7 of 7
Thread: Cleaning a filter cartridge?
    Jul 2015
    Leland/NC
    24
    I have the filter from my pool last year. It was only used for about 3 weeks before my pool turned into a swamp. I pulled it out today and ut doesn't look that bad. I've got it soaking in bleach after rinsing with hot water and brushing the debris out.
    Do you think I'll be able to reuse in the new pool?
    30,420
    Re: Cleaning a filter cartridge?
    I am not a cartridge owner but there is an article in Pool School on how to clean cartridge filters.
    Mar 2007
    San Rafael, CA USA
    12,082
    See Cleaning a Cartridge Filter. You do NOT want to soak the cartridges in bleach, certainly not anything too concentrated. How much bleach did you put into how much water? Was the water you used tap water so had no CYA in it?
    Jul 2015
    Leland/NC
    24
    Tap water and about a cup of bleach.
    Jun 2014
    15,121
    I use a standard Hayward replacement type cartridge for my pool. Typically I just use a good water nozzle to apply a good direct stream of water down the "ribs" of my filter. I keep a spare on-hand just in case. The spare I soaked in a mixture of regular tap water and Cascade (granular) dishwashing soap. It did a fairly good job. But my cartridge is only about $50 through Amazon, so it's almost just as easy to buy a new one rather than to try and salvage one through soaking rinsing, etc, etc.
    Mar 2007
    San Rafael, CA USA
    12,082
    So one cup of 8.25% bleach in 15 gallons (say in a 20 gallon garbage can) would be 360 ppm FC. That's not enough to destroy the cartridge (at least not very quickly) so that is good, but you don't need to do this since cleaning is more effectively done using trisodium phosphate (TSP) or dishwashing detergent or a commercial cartridge cleaner as described in the Pool School article.
    Jul 2015
    Leland/NC
    24
    Thanks! Was trying to see if I could save this filter....I hate to throw away money lol.
