Results 1 to 8 of 8
Thread: New Conversion. Salt at 4100. Empty and Re-Fill?
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    Just converted to SW. Added 9x40lb bags last night. Plumbed in today. Reading at 4100.
    Should I empty and re-fill with fresh water, or let it go for a couple of days?
    16k gal, IG pool and spa, pool 29x14, pebble, 1983, 1.5" plumbing, Pentair Intelliflo VSP, Pentair Quad DE, Zodiac Aqualink Z4-PSi, AquaRite T15 SWG, Aquatherm AT115
    38,251
    Re: New Conversion. Salt at 4100. Empty and Re-Fill?
    It is best to not turn the SWG on for 24 hours after adding salt.
    Did you measure the salt content in your pool before adding salt?
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    I used the test strips that came with the Hayward. The pump ran all night and the SWG did not get turned on until last this morning. I would say it was a good 13 hours. The test strip barely showed a reading above 1 before I added the salt. I was about to add more salt because the test strip barely got above 2 this morning after adding 320lbs! Then the SWG registers 4100 after turning it on.
    Should I turn the SWG off?
    Jun 2015
    Ottawa/Ontario
    336
    It usually recommends mixing for 24 hours. You may not get an accurate salt reading until then.
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    As long as the amps don't get to 8, it should not give a "high salt" error. Try brushing the entire pool and add some fresh water if the water level is a bit low.
    Can you post the diagnostics? (The numbers displayed when you push the black button near the display).
    Also note that nine 40 lb bags is 360 lbs.
    What cell do you have?
    Support the site
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    Unit is off for now. Pump is on @ 1,700rpm. Double checked and I did add 9x40lb bags.
    4100
    90
    31.3
    0.00
    30P
    -0
    AL-0
    r1.59
    t-15
    AquaRite T-15
    Try again tomorrow after brushing today and allowing for more circulation.
    The fourth number is amps. As long as that stays below 8, you're good.
    The reason I noted the amount of salt is that you say 320 lbs in one post. Just wanted to clarify which it was. 360 lbs in 16,000 gallons is only 2,700 ppm. Unless you started with high salt, you should be ok.
    Support the site
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    This is from the manufacture. I believe in 48-72 hours before you do anything to the salt level. As long as the unit is not showing high or low salt do nothing for a few days.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
