Thread: Air Bublles from my Jets and cloudy white stream - Jandy Valve o-ring FIX
    After 5 years and painful amount of time and reading with 4 different pool guys. I found it. thanks to TFP. Saw a video on sucking side leaks. Went through the video and unbelievable the Jandy 3 way valve o-ring was installed incorrectly and so many people missed it. Picture attached.
    Initially it was the SWG - cleaned it
    Then it was O ring on Pump cover - fixed
    O-ring on pipe connections on sucking side - fixed
    Pipe clamps not tightened enough on intake pipes.
    It all added up, but still I was getting intake air. Now my Jandy 3 way valve got 3 new O-rings all fixed. No bubbles and no more white stream.
    Thanks TFP and all the users out there!
    Enjoy the summer and your pool!
    50,000L/vinyl - Aqualine Goldwater SWG. T-cell 15/Pentair Plus 520 Cart Filter, IntelliFlo VS-3050, GoldLine Wireless Automation with Solarium heat pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Air Bublles from my Jets and cloudy white stream - Jandy Valve o-ring FIX
    Good deal! Tiny little things can be a pain to track down.
