Results 1 to 7 of 7
Thread: Can we take vacation a few days after we neutralize our water from an Acid Start up?
    Feb 2015
    Leesburg, Va
    164
    So our timing is going to tight. Looking at factors to determine if we need to make special arrangements.
    We have no clue what is involved(or how long) in getting the pool chemistry correct after our start up.
    We have a vacation planned about 10 days after we do our acid start up. The plan is Monday apply quartz. We think it will take two days to fill. Then the PB applies the acid start up. We plan on brushing 4 times a day. So, one week later we are at Wednesday or Thursday. The PB adds the neutralizer. That gives us 2 days to balance the water. We go to the beach on Saturday. We think we can get some one responsible to brush twice a day for the 6 days we are away.
    Our thoughts:
    1) How difficult will it be to get the chemistry correct after the acid is neutralized? Will it require more monitoring over the days we are going to be away?
    If this is a critical period (we have brushing covered) for chemistry we may just have one of us go to beach with kids and the other stays and monitors. We don't want to postpone the finish. August has a hectic work schedule.
    Pool build spring/summer 2015. IG. 750 sq ft pool. 40 sq.ft spa. 18ft x 42ft rectangle, 31,000 gallons, SWG, DE Pentair model, 2 boosters variable speed model, heater master temp Pentair, Quartz finish Aegean Green, CoverStar Automated Pool Cover, Kreepy Krawley Platinum, TF100,SpeedStir My Build in Progress
    30,411
    Re: Can we take vacation 3 days after we neutralize our water from an Acid Start up?
    What does your PB say?
    Feb 2015
    Leesburg, Va
    164
    Will discuss with him tomorrow.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Can we take vacation a few days after we neutralize our water from an Acid Start
    Should be able to get PH stable at 7.2. It will likely rise from there but not above 8 in 6 days. Add cya and bleach up to shock level. Have the person brushing add 3 or 4ppm of bleach every day or two.
    Use the Chlorine CYA Chart to set chlorine level. Use Pool School - PoolMath to determine how much bleach.
    Feb 2015
    Leesburg, Va
    164
    Met with PB.
    If we go with quartz tomorrow (they will prep the pool in the morning and then do a weather another weather check -we have been getting a lot of rain) then he will stop by mid week while we are away and test the water and apply chemicals as needed.
    So the hope is an all included family vacation. Fingers crossed on the weather.
    Feb 2015
    Leesburg, Va
    164
    Weather delay, shooting for Thursday or Friday. Our build is taking a long time so when we get a non rain window we will take it. Will just have to re-work vacation plans some how.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,215
    I'm sorry about your vacation plans. At this point, I imagine you guys could really use a get-away. Like you said, you need to take that weather window when it comes. You know it will all work out. It just may be a little different than you planned. I'm hoping the all included family vacation will happen. Everyone in the family needs it! Thank goodness your builder will help out while ya'll are gone - whenever that works out!
    Fingers crossed for you guys!
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
