Results 1 to 11 of 11
Thread: Deep cleaning pump and the standpipe did not come loose from the head
    Jul 2011
    Tavistock, ON, Canada
    33
    Hello all! We decided to give our pump a deep clean,the pool is 8 years old and we have never done it. When we removed the head the standpipe was still connected to the head and now has become dislodged in the sand with the laterals still attached. Is there anyway we can straighten the standpipe and laterals without removing the sand altogether? Does anyone know of a way to get the stand pipe off the head? It is a Hayward pump S-220-T
    Thanks in advance!
    Leanne D
    Leanne
    18x36 IG Vinyl, Zodiac SWG, 1.5 hp Jacuzzi pump , Sand Filter, installed 2007
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,543
    Re: Deep cleaning pump and the standpipe did not come loose from the head
    I don't want to be the one to tell you but.......... you are going to have to take the sand out to reset the pipe and laterals.
    To take the pipe out of the head you need to gently turn and pull the two pieces at the same time. It might be best to have two people working on it. Slow but steady should do it.
    Kim
    Jul 2011
    33
    Lol....I thought so! My hubby did get the pipe off but it took a lot of work due to how far the pipe was inserted in the head. We know now why it was hard to get off.....his hand shows how far it was inserted into the head (over 4 inches) and the damage that was done to the pipe when the pool company put the pump in. Does anyone know how far should the pipe fit into the head assembly. We are thinking of cutting off part of the pipe to make it easier to remove. Would this be ok? The sand is out and I am going to give it a rinse, then we will reinsert the standpipe and laterals.
    Thanks so much for the info!
    Leanne
    Jul 2012
    Tallahassee, FL
    30,543
    Leanne,
    Do you have the manual for the filter? If so please find it and see how far it show the pipe goes up if it shows it. I am going to ask some of the more experienced people on their thoughts. Hold tight.
    Kim
    Jul 2011
    33
    I found an online manual and it does not give a depth. We found a YouTube video on the installation of the S-220-T and the pipe certainly does not look like our pipe. We may just leave it until Monday and go to the pool company that installed it and get their opinion. It doesn't make sense to put the sand back in if we have to replace the standpipe.
    We just can't seem to figure out why the pipe would look like that. It seems like it should just slip into the house on the valve cover but this pipe has been mangled!
    Thanks so much for your help kimkats!
    Leanne
    Leanne
    Jul 2012
    Tallahassee, FL
    30,543
    Mangled is a good word for what you pipe looks like.
    Hummmmmmmmm I wonder if that is the correct pipe for your filter??? Did someone as some time replace the pipe and force it on?
    Just thinking out loud here.
    You can put bleach in the water and walk around and stir it up to keep it from getting green.
    Kim
    Jul 2011
    33
    Ya I am not sure, they must have really had to force it on to get it to look like that! It is the original pipe.
    Thanks for the tip with the bleach!
    Leanne
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I don't know the answer either. But this guide with pics might help.
    Deep Cleaning a Sand Filter
    Jul 2012
    Tallahassee, FL
    30,543
    Looks like your best bet will be to take the parts to the pool store and see what is normal for your filter.
    Throwing this out there------------call the manufacturer of your filter and ask them about it. Ask if you can send them a pic of your pipe and see what they think happened. It is worth a try. You might have to talk to a couple of different people to find one that knows what they are talking about but..........
    Kim
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    This is Hayward talking. Someone really mangled that pipe. It should easily slip up into the valve about 2". the part number for the lateral standpipe assembly for the S220T is SX220DA. If you are removing the sand please replace with new #20 silica sand.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    A lateral assy is 50 bucks online, though I think last year I found one for $25.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
