Thread: Closing For A Week?
    Apr 2015
    Leesburg, GA
    49
    Closing For A Week?
    Going on vacation for a week this month (July). Intex, 20' AGP. How do I "close" to prevent algae during my absence?
    20' Intex; 52" deep; 8,638 gal; above ground. Intex 1,600 GPH sand filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Closing For A Week?
    Best thing to do is probably lower PH to 7.2 and raise your FC to shock level. Have a neighbor stop by and add rppm of bleach every other day or so. Put a cover on it if you have one.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I just raise the water a couple inches to allow for evaporation and stuff a floater with trichlor pucks. If you have a cover, put it on. Assuming the pool chemistry is good right now, some Polyquat60 algaecide might buy you some peace of mind. It's lousy as a cure, but good as a preventative. (Although it's unnecessary in a pool that gets maintained regularly, so no one reading this should consider algaecide a substitute for chlorine. It's just for when no one is around to care for the pool)
    The search box will provide you will many more ideas.
