Thread: Plumbing for Hayward thru the wall skimmer
    May 2015
    Arab, Alabama
    2
    First time pool owners just bought an Intex 18 round. We also purchased a Hayward thru the wall skimmer but keeping the cartridge pump til next year. We are confused on how to make the plumbing work without leaks and having flexibility. Got to have a valve in there somewhere too. The 1.5 to a 40 mm diameters using the hoses that came with the pool. Any help would be greatly appreciated!
    I just purchased a Intex Ultra Frame 18' x 48" round above ground pool.
    Casey's Avatar
    SW PA
    10,457
    Re: Plumbing for Hayward thru the wall skimmer
    Welcome to TFP. Lets see if we can find someone to help you with your INTEX Plumbing.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Here's what I did:
    Hose clamped the Intex hose to the tapered adapter on the skimmer, and moved the valve to the pump end of the hose.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    How long is the filter output hose, not too long?
    Also, is the hose type, is it for high pressure? The one going between pump and thhe filter input, make sure it can take the pressure, in these systems usually between 10 and 20psi.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
