Results 1 to 11 of 11
Thread: Omnilogic sense and dispense
    May 2008
    Marana AZ
    45
    I installed a sense and dispense on my new pool with omnilogic. I have it wired up correctly and went through the configuration and everything appears to be correct. The omnilogic recognizes the hardware but is not showing any readings. The manual from Hayward is not much help. Any ideas?
    Oct 2014
    Central PA
    87
    Re: Omnilogic sense and dispense
    Which reading are you looking for, you should get a ph, and an orp, but not on the same screen, it's not a good idea to use orp to control the swg, it's not reliable enough,
    If you touch the left side of the screen do you get a ph selection. If you do then the reading on the left is your ph, and the reading on the right is your set level
    May 2008
    Marana AZ
    45
    Quote Originally Posted by heatdissipation View Post
    I am not getting either ph or orp readings. Just dashes where the reading should be.
    Oct 2014
    Central PA
    87
    Might be a silly question, but are your probes plugged in, and into the right spot, they are labeled which is for ph and for orp
    Oct 2014
    Central PA
    87
    And water is flowing through the unit?
    May 2008
    Marana AZ
    45
    Yes
    Yes
    Oct 2014
    Central PA
    87
    Try resetting, **** power off and then back on, that is what solved my app connection problems
    May 2008
    Marana AZ
    45
    That doesn't help
    Oct 2014
    Central PA
    87
    Hmmmm. Double check to make sure it's hooked into the right spot, which I am sure you have already did, and try reconfiguring it again, if that is no help, then I don't know what the problem could be, mine worked right out of the box, so troubleshooting it beyond what I already suggested is beyond me. Sorry
    May 2008
    Marana AZ
    45
    Sounds like I need to call Hayward
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    From the comments I can not tell what is happening. Call 908-355-7995.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
